Old 04-29-2007, 08:57 PM   #1
1970bowtie
1970bowtie's Avatar
rear end question
im going to be getting a 373 factory posi rear end soon, problem is its six lug.i can use my five lug axles if there the same spline count right?
Justin
1970 c/10 short wide bed
WTT 1970 chevy front end for 67/68 chevy front end
WTT 2 15x10 american racing outlaw 2 wheels for 2 of the same in a 15x7 or 15x8
1970bowtie is offline   Reply With Quote
Old 04-29-2007, 09:16 PM   #2
1970bowtie
1970bowtie's Avatar
Question Re: rear end question
anyone know?
Justin
Old 04-29-2007, 09:19 PM   #3
1969k10stepside
IIRC,the 6 lug axles were wider than the ones that were 5 lug.But I also think I remember in late 69 or 70 they did become the same width,just 6 lug.Sorry I cant give you a definite anwser.Maybe someone else will jump in a give you some more info
1969k10stepside is offline   Reply With Quote
Old 04-29-2007, 09:19 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if it is out of a 70, then you might be able to do it.
The 67 - early 70 were narrow, while the mid 70 - 72 were 3/8 inch wider on each side.
Old 04-29-2007, 09:21 PM   #5
1970bowtie
1970bowtie's Avatar
thanks for the help guys, dont they make a kit to go from a 6 lug rear end to a five?
Justin
Old 04-29-2007, 09:22 PM   #6
uncle
If it measures 57" from backing plate to backing plate,you can swap axles.
uncle is offline   Reply With Quote
Old 04-29-2007, 09:27 PM   #7
1970bowtie
1970bowtie's Avatar
thanks for the info uncle i hope it will work.. this way i wont just blow one tire ill blow two
Justin
Old 04-29-2007, 09:55 PM   #8
71 super
71 super's Avatar
If you already have a 3:73 gear in yours but a peg leg, why not just swap carriers instead of entire rear ends? Pull ring gear off of one and replace with ring gear out of existing 5 lug. The carriers are the same but the axle lengths are different- what ever you do do, do not mix and match gear sets.
71 super is offline   Reply With Quote
Old 04-29-2007, 09:59 PM   #9
1970bowtie
1970bowtie's Avatar
good idea super. but im not sure whats in the rear end i have now
Justin
Old 04-29-2007, 10:12 PM   #10
Goodguytrucks
That is what I did....swapped the posi gear assembly and pinion gear into my 5 lug non posi rearend...I haven't driven it yet but it all assembled good
Goodguytrucks is offline   Reply With Quote
Old 04-29-2007, 11:25 PM   #11
65-72 chevytoys
65-72 chevytoys's Avatar
When you pull the diff cover the carrier unit where the ring and pinion gears are located will have either 4 small spider gears or springs and disk plates. If it is spider gears it is an open diff. if it has any springs it is already a posi.
2004 Chevy Silverado 1500LS SWB 5.3L
2004 Corvette Z16 #770
Wish I had not sold 72 blazer
65-72 chevytoys is offline   Reply With Quote
