Distributor question?
Here is another one to throw at you. this truck came without the stock distributor, in its Place is a HEI distributor. The white resistor wire (cloth wire) that comes from the firewall to the orig. coil has been cut and spliced with a regular wire (not sure what ga.) which now goes to the HEI distributor. I want to replace the existing wiring harness with a new one, will there be a problem with using the new harness resistor wire with the HEI distributor? I guess what i'm asking is does the HEI need a special type of wire different than the resistor wire which will come in the new harness? Has anyone used the HEI in this fashion?
Re: Distributor question?
M&H makes an engine compartment factory look alike wiring harness all set up for an HEI dist. I have one...they are plug and play units! Plug it in the firewall hook up the ends where they go and turn the key.
Alex 1971 Lil' Red 350 SBC 700R4 |
#3 | |
Sierra Grande Club
Any pictures? s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
To answer your orignal question, the HEI must have a regular wire not a resistance wire (it needs a full 12V, actually more like 14V when running).
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
There is an article in the FAQ that explains on how to wire a non stock HEI.
http://67-72chevytrucks.com/vboard/s...ad.php?t=17403 It explains on what was said above the HEI needs 12 volts while points would burn up at 12v so that is why you have the resistance wire. Follow the steps in the FAQ post and you should be good to go.
2004 Chevy Silverado 1500LS SWB 5.3L 2004 Corvette Z16 #770 Wish I had not sold 72 blazer |
Here ya go:
http://www.wiringharness.com/
