Sierra Grande Club
Pictures of cowl screen.
I plan on making a screen possibly out of .125 DIA perforated aluminum. How are you guys attaching the screens that you are using? What cool ideas are you using? Anyone have a template?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
Sierra Grande Club
Re: Pictures of cowl screen.
Anyone use the stainless unit that GMC Paul sells?
I make the screens out of 1/4" mesh, galvanized hardware screen for our trucks, (I have installed (6) so far. They work very well to keep the leaves out.
The material that I have is not long enough to go all the way across so I use two pieces about 4" wide overlapping them to insure coverage. I cut holes out for the squirters and wiper arm shafts. I paint the screens with a flat black and when installed the screens are almost invisible. The screen is trapped between the cowl and cowl cover with the mounting screws installed through the screen. Here is a pic of the screen as installed onto my 71. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC Last edited by JimKshortstep4x4; 10-08-2007 at 07:59 PM. |
