Old 04-30-2007, 03:31 AM   #1
hewlett2002000
hewlett2002000's Avatar
know where i can get a cheap radiator?
ok yall i need a new radiator and electric fan setup for my 66. do yall know any online stores or anything where i can get it cheap? i know summit has some for around $100 but are they any good?
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 04-30-2007, 08:33 AM   #2
19GMC63
19GMC63's Avatar
Re: know where i can get a cheap radiator?
Summit has a cheap universal radiator, and since yours is a 4 spd, its even cheaper, around 170. Fits perfectly in the lower mounts, you just need to fab some brakets for upper mounting. I can snap some pics of mine if ya want me too.
http://store.summitracing.com/partde...5&autoview=sku
As far as electric fan, everybody carrys 'em, personally, I'll stick with mechanical.
19GMC63 is offline   Reply With Quote
Old 04-30-2007, 10:03 AM   #3
hewlett2002000
well i dont have a shroud and im having a hard time finding one. thats why i want the electric fan.
Respect:
Old 04-30-2007, 04:26 PM   #4
19GMC63
19GMC63's Avatar
I'm not using a shroud, and everything appears to be staying cool.
Temp gauge says I'm running around 165* w/ a 180* thermostat.
Old 04-30-2007, 06:31 PM   #5
Jonboy
Slots go on anything!
Have you checked at Autozone or O'Reilly's yet? I hate to suggest them, but they do have inexpensive radiators, with a lifetime warranty.
Old 04-30-2007, 08:40 PM   #6
ClassicAutoResto
Rust Buster
ClassicAutoResto's Avatar
I run an O'Reilly's, I just called my store and you can get one new for $241.99 with a lifetime warranty. Good luck!!!!
ClassicAutoResto is offline   Reply With Quote
Old 04-30-2007, 10:30 PM   #7
Dadsredwagon
Dadsredwagon's Avatar
radiator .com I bought one for my jeep?
Dadsredwagon is offline   Reply With Quote
Old 04-30-2007, 11:25 PM   #8
Revin68
Recreational Grease Monkey
Revin68's Avatar
I've installed an '88 chevy fullsize PU radiator and shroud. Mine came with the engine for a customers project so it was free to me but, it should be cheap and easy to acquire. Basicly a direct bolt in. I made simple brackets from angle to mount the bottom of shroud. Been on the truck for 13 yrs with no problems.
Good Luck,
Robert
Revin68 is offline   Reply With Quote
Old 04-30-2007, 11:47 PM   #9
hewlett2002000
well a friend of mine just gave me a 84 chevrolet pickup. ill just try that. thanks.
free to me too!!!
Respect:
Old 05-01-2007, 12:30 AM   #10
Revin68
Revin68's Avatar
Gotta love the price! Good luck.
Robert
Old 05-01-2007, 02:04 AM   #11
hewlett2002000
hey revin. any chance i could see a pic? mainly of the brackets you made?
thanks,
John
Respect:
Old 05-01-2007, 07:29 PM   #12
Revin68
Revin68's Avatar
Sure, The first two are the overall rad/shroud mounting. The next two are the bracket viewed from the top down. Last is from the ground looking up. Nothing fancy here, just two pieces of angle welded into a Z shape and welded to the core support. It is then bolted to the bottom of the shroud (which is also the radiator mount for the top and bottom). This is an '88 model rad/shroud combo. It is the first year for the redesigned PU, its probably a little different than your previous version. Its always trial and ERROR. LOL
