Wrenchin & Sandin!!!
Who has used 3M 8307 Self Leveling Seam Sealer
How much does it take to do the drip rail on 1 cab? And also how do you seal the vertical part of the drip rail? Seems like this would just run off? TIA.....
Randy ![]() Shorewood, IL. My Favorite eBay Searches My Driver Restore Thread 1971 C10 Longbed 2005 Silverado Shortbed 2005 FXDWG |
Re: Who has used 3M 8307 Self Leveling Seam Sealer
Yes it will run off in the vertical seams. You are probably better off using the 3M Heavy Bodied Seam Sealer. You could probably get it done with one tube but I would have second one on hand just in case. If you do not use it than you could always return it and get your money back.
Thanks 72CSTC5. After doin a search I thought that the 3M #8307 was the way to go......guess not? Do you have a part # for the 3M Heavy Bodied Seam Sealer?
member #16
![]() Join Date: Dec 1999
Heres a few sealers. Fast N Firm and Drip Check will work with vertical seams.
http://www.autopaintersupply.com/Mer...egory_Code=3BS
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 04-30-2007 at 02:18 PM. |
Weekend Warrior
3M - 8308 is the "Heavy Bodied Seam Sealer"
Dont' forget though even with the "Self Leveling" you'll need the Gun to apply it as these are 2-parts. There are some other's that will go in a caulk gun or just brush on. Applicator Gun (this is one of the cheaper ones (but is still a very nice quality): http://www.autobodytoolmart.com/pc-1...artridges.aspx Heavy Bodied: http://www.autobodytoolmart.com/pc-1...ler-08308.aspx Self-Leveling: http://www.autobodytoolmart.com/pc-1...ler-08307.aspx
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() |
