![]() Join Date: Oct 2006
Longhorn bed question!
Would a 1972 Chevy Longhorn bed fit on any 67-72 3/4 ton GMC or Chevy truck? does the Longhorn have a bigger frame than a 3/4 ton?
Thanks! |
![]() Join Date: Feb 2004
Re: Longhorn bed question!
The frame is longer and it is normaly a 1 ton frame (length wise)
Andy will pipe up with this.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
OzarkHillbilly in Atlanta
frame is longer on a Longhorn.
72 custom/10 LWB 68 Longhorn C20 Custom Camper (sold) |
So.... all Longhorns have a 1 ton frame?
no,some were 3/4 tons
Saving 1 truck at a time!
Yes. The Longhorn bed will fit as long as you remove the front, 6", extension and replace it with a standard box front. The Longhorn frame is a one ton frame and is 9" cross section channel. It is also 6" longer than the 127" wheelbase frame.
Even the 3/4 ton Longhorns had the 1-ton cross section frame since it was a longer wheelbase and was designed to carry a heavy camper.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) Last edited by stllookn; 04-30-2007 at 08:51 PM. |
I love this site!! I just wanna make sure I got this right, in order for me to use a Longhorn bed the frame must be a 133" wheelbase frame?
![]() Join Date: Mar 2003
its all about the +6 inches
yep, all is correct here... all longhorns had one ton frames, they were taller than a SWB or LWB frame too, and the longhorn bed can not be properly bolted onto a 127 inch wheel base.. the added section is at the front.
