4 speed, hurst shiftin
how much?
i have the opportunity to get a rack , and pump for powersteering for free , the bent pulley being the only set back , and needing a new pitman arm i think? or is it idler arm, and a diff length belt? what all would i need , and what would it cost assuming the pump and rack are free....
Shane 1970 Chevy C10 |
What do you mean by rack ? Are you taking about the P.S. box or a rack and pinion unit. You can get a pitman arm for around $30, pulleys are $10 or more, depends on where you find it. I assume your getting the hoses also. If it's a rack and pinion unit, good luck on setting that up. It's not a bolt in, your going to be fabbing lots of stuff to get it to work.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
