L.E.D. Freak
Cheapest Rear Air Bag Set up?
I want to put Air Bags on just the rear of my Blazer, Then upgrade later. The bags must have 1/2 threads, at least. I plan to just put air lines to under the rear bumper, with valve on each side, with air chuck fiting, and maybe pressure gauges. How much are decent, bags and a mounting kit?
Specializing in Custom L.E.D. inserts. http://www.ccled.com/ Contact me @ blazer2wd1972@hotmail.com (406)675-8082 or Joel @ jmcwaters@eps-corp.net 1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL |
its all about the +6 inches
Hmmmm, $29.99 Sears Air shocks?
LOL...just kidding! |
PROJECT LO-LYF
Check out the link below.
I got mine through air ride technologies but this place sells all kinds of brackets, bags, etc... good luckhttp://justairbags.com
FOUNDING MEMBER OF THE "O-SH*T, THAT TRUCK IS LOW" CLUB PROJECT: LO-LYF Bagged 68 Shorty home.att.net/~justin.lewis |
I put air products air bags in my rear drop springs so I can still haul and tow stuff. The whole kit cost 65.00 delivered.
www.airliftcompany.com/indexAL.htm
69 SWB C/10 5-6 drop 700R4 69 Firebird Convert 455 4 spd 70 Torino GT Convert Austin-Texas |
L.E.D. Freak
I'm looking for regular bags, with 3/4" port, and aluminum plates. I probably just go threw Air Ride. DO you have to weld the brackets on the chassis? And can you add C-notch later?
Progress = 0%
IMO you really don't need brackets for the rear. I just mounted mine where the stock coil spring goes. Drill holes in the bottom of the frame for the air line and mounting studs. Pretty easy.
Just curious, but why do you want 3/4" ports??? To make it raise and lower faster? I'm running 3/8" line in mine and it is plenty fast.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra Last edited by Slammed67; 09-10-2002 at 01:20 PM. |
L.E.D. Freak
Slammed 67
You have a Early C-notch right? What Part # bag/ size are you using? I want 3/4" ports to keep my options open. I'll most likely use 3/8" lines at first. You have any close-ups of your rear bag set-up?
Progress = 0%
Ryan,
I've got the Classic Performance Products C-notch, 2500lb firestone air bags, and 3/8" line. With the tanks full (at about 140psi) and without the bed, the back end jump up in less than a second! It'll slow down once the bed is on, but it'll still be quick. 3/4" port bags probably don't cost much more than 3/8" bags anyway, so I guess you might as well get the bigger ones. I'll send you some pics of mine this evening. Oh, I sent you that GMC park lamp housing/lens. You should get it by Friday or Monday at the latest.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
chevelito
sup slammed,
I'm just posting cuz I want email notification if there are any posts. is there a difference between the ECE and the CPP panhard bar relocators? I know people had trouble with both. I just want to know which one will be the easiest to modify. jay
New deadline...when my son can drive. ![]() Aloha from Honolulu, HI |
PROJECT LO-LYF
yea slammed, I guess your right about not needing brackets for the rear, I never thought about that.
I am running measelly little 1/4 inch line on mine and it even rises sufficiently. The guys at Air Ride talked me into buying two, three gallon air tanks, but I have just one hooked up now and it raises both the front and the rear of the truck fine before the air runs out.
Progress = 0%
Jay: I'm not sure how the CPP panhard bar attaches so I can't explain the differences. If you go with the ECE bar and a CPP c-notch, you'll need to modify where the bar attaches to the passenger side trailing arm. There is an interference problem with the two.
Justin: I originally bought 1 3-gallon tank and one compressor, but it didn't seem like it'd be enough. So now I have 2 of each. With one tank you'll probably not get more than one rise out of the tank before it has to refill.
PROJECT LO-LYF
Exactly, after I raise the truck, the compressor kicks on and refills the tank. I suppose I will eventually add the second tank when my bed is complete.
#13 | |
chevelito
ok...here's the info I got from the cpp website regarding the track bar...looks like it hooks up to the stock location on the pumpkin therefore will not interfere. Please correct me if I am wrong. Witht he ECE, the rod is extended to the other trailing arm as slammed has indicated.
![]() jay
#14 |
chevelito
just a little follow up on this.
I took out my rear coils and shocks over the weekend and the bed now rests on top of the axle via the rubber bumpstops. I can see now that the CPP will not work because the angle of the track bar will be too far. Instead of the bar being higher on the driver side, it will be lower when it is lowered that far. I see that the ECE way is the only way to go unless you go custom of course. jay
#15 |
SLICER AND DICIER
GOT Co2!!! GOT NITROGEN!!! GOT HELIUM!!!
They all work great! I use the Co2 it seems to last longer. Helium is for the hoppers, it atomizes faster, so they say. I just don't like the ANNOYING buzz of the compressors. But I must admit I do have one as a back up in case I run out of Co2 away from my house. The new V-belt driven compressors are INTRUGING, 6 gal tank in 2min, THAT'S IMPRESSIVE!! JMO ![]()
01 Tahoe 22's 2/4 drop and tv's ![]() 68 chevy money pit 51 chevy belair 95 Honda 900RR 05 GMC Siearra (company truck) |
#16 |
Flamin' Bass
Just my $0.02:
I'm running 1/2" lines through 10mm (~3/8") SMC valves and a single 5gal 4 port tank using nitrogen. Now that I finally got the switches installed in the cab, I can see exactly how this setup works. I ran the tank up to about 120lbs and hit the front switch. Yup, it's fast! My only complaint is that I'm using up the nitrogen at an alarming rate. Went through about 500lbs just testing. I kinda hoped it would last a lot longer that that. But giving the neighborhood kids 'rides' and trying to flip them off the rear frame does use up that gas! NSANE68: Hmmm, a spare electric compressor, that sounds like a good idea. I'd hate to get caught with an empty bottle out on the road. Sure beats carrying a bicycle pump! BTW: I didn't have any problem with the adjustable panhard bar supplied in the EasyStreet kit. Can't wait to get the truck on the road; just cranked the engine over for the first time since last October. Started right up, but boy those Flowmaster 40s seem louder than they did last year!!
Rick Olson /nosto/ Galloway, NJ Pics : http://community.webshots.com/user/nosto53 1972 Triumph TR6 - full resto, now with a Toyota 5-speed 1975 F**D F-100 - rusty, but reliable 1982 HD XLH-1000 1967 C-10, shortstep, 350/M21 4spd, nitrogen tank fills fast bags on 4 corners, Toyo 255/45X20s on American Eagle 221 20X8s, shaved locks and handles, antenna, fuel filler, tiny C-notch, rear fuel tank, long headers, Edelbrock, worn 600 Holley, Checkmate flush hard cover, rear pan, custom LED taillights - painted it, too! But don't like it so I'm gonna do it again!! |
#17 |
SLICER AND DICIER
Try Co2 on your next fill, seems to last longer.
#18 | |
Co2 is in liquid form and I believe the same bottle witll last nearly 12 times as long. The only proablem is that the bottle has to be upright so you do not pump out liquid and if large volume of gas is use it can carry some liquid and the regulator can freeze up. Good luck Ed ke6bnl
Ed ke6bnl Agua Dulce 70 S.E. Los Angeles 70 Chevy short bed 1948 F3 ford pu 1949 F1 stock V8 flathead 3 on floor 1950 F1 pu street rod 1948 F6 Ford Dually/350sbc no bed stock trans&rear 1972 El Camino 4" chop 1953 Chevy 3100 2b daily driver 1970 SB 4X4 400ci 6in lift |
#19 |
SLICER AND DICIER
Good point. I keep mine tilted up at an angle, and run it through a spin tank giving it more time to go from liquid to gases.
#20 |
Old Skool Club
![]() Join Date: Jun 2001
....on the track bars (panhard rods)...Early Classic Enterprises is ADJUSTABLE, while CPP is fixed, at either of two lengths (24 or 27-inches). I lowered mine 4-inches, in the rear. The shock mounting had to be changed to restore the shock angle to a workable one, as well as the use of the adjustable rod to center the rear axle under the frame. You should find that as you change the height of the body, in relation to the frame, that the rear axle centering will change. Based on the use that I have seen people make of the air bag system, you probably won't have a "one position adjustment" that will work. You'll have to decide where it will be when you are driving, and let that be your guide as to where to adjust the panhard rod. Above or below that setting, and your rear axle will be more to one side, or the other. How much? Don't know. My lowering was done with springs and spindles. I'd like to have air bags in the rear, just to be able to "play" with the height. But, since I pull a utility trailer from time-to-time, I don't need that adjustability. Besides, I can still get nose-bleed from getting into my Tundra or the school bus I drive. Getting into my lowered (3.5/4-inch) '69, reminds me of my old TR-3, except my knuckles don't drag the pavement when I reach out of the window (after driving the bus, doncha know).
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
