Old 04-30-2007, 11:41 PM   #1
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Problem with new Master Cylinder.......
Ok, I have my truck running really well now, with the updated engine.
I'm having an issue with getting the brakes to bleed. I was told that the 'REAR' port on the master feed the front brakes, and the 'FRONT' off the master feed the rear brakes.
Now, I purchased a NEW drum/drum master for a '67 Impala...it bolted up really nice.
I went to bleed the brakes today...the rear brakes have mega-pressure, but I can't get nothing from the front....barely pours out.
Now someone here (I forgot who) told me the the front res. feeds the rear port and vica-versa......As I bleed the rear brakes, the front res. drains (??)
Could this master be different or bad ??
This is all I need to get the 'Chief' on the road !!!
Any ideas....I know this should be a no-brainer, but....'what the f##k !!!'
John
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 04-30-2007, 11:45 PM   #2
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: Problem with new Master Cylinder.......
For those who haven't seen my build this is the Master and the how the ports were hooked up....
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-30-2007, 11:56 PM   #3
Pistonman
Did you bench bleed it?
Pistonman is offline   Reply With Quote
Old 05-01-2007, 12:25 AM   #4
slepysal
slepysal's Avatar
i think the ports may be wrong If I rrecall the small resivour feeds the rear , the larger onr the front. try this link
http://www.classicperform.com/TechBo...oubleshoot.htm
slepysal is offline   Reply With Quote
Old 05-01-2007, 08:18 AM   #5
62 short step
62 short step's Avatar
I thought the port close to the fire wall was for the rear brakes?
62 short step is offline   Reply With Quote
Old 05-01-2007, 08:49 AM   #6
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
OH YA...I bench bled it for days !!! It took a while, but I got every last little bubble out of the darn thing !!!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-01-2007, 08:54 AM   #7
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I will check it out. However, on this Impala master the resivours are the same size. I thought the larger port (front) was the front brakes...RICH told me the front brakes were the rear (?!?!?)
It sucks, because I had my lines bent perfect, now I might have to switch them...
JOhn
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-01-2007, 09:46 AM   #8
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Also...there shouldn't be a need for a prop. valve with a drum/drum set-up, right ??
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-01-2007, 10:07 AM   #9
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
Chief, yer friend Rich is correct, the larger port (usually front) with the smaller reservoir usually feeds the rear brakes, and the smaller port with the bigger reservoir usually feeds the front - has to do something with different pressures required, or something along that line. You have the same size of reservoirs cause yer brakes are drum/drum so they require about the same amount of fluid to go in all of them, however the pressure difference requirement is still there. So hook yer front brakes to the smaller port, the rears to the bigger one, and try to bleed again.
Another thing to look at are the flexible brake hoses - with age those tend to disintegrate and collapse internally, thus blocking fluid from going in and out.
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 05-01-2007, 10:34 PM   #10
Dadsredwagon
Dadsredwagon's Avatar
any pics of your 71 nova ss I own a 72 model....
Dadsredwagon is offline   Reply With Quote
Old 05-02-2007, 12:14 AM   #11
wild one
Registered.........
wild one's Avatar
Thought this might help, I found this some time ago on EVILBAY - Good info and explanation. The seller is http://myworld.ebay.com/pirate-jack-asheville-nc just look up any proportioning valve that they list and scroll down, lots of other interesting stuff.
Are the brass fittings on the master cylinder adapters or one way valves? Possibly residual valves?
DRUM BRAKES FRONT AND REAR WITH MASTER ON FIREWALL OR UNDER FLOOR
* drum/drum, firewall or under floor
Drum brakes require a 10 lb. residual pressure (RPV10) to counteract the spring tension in the drum system which tends to pull the shoes away from the drums. This will give you a longer pedal travel and "spongy" brakes. The residual valve holds a pressure keeping the shoes near the drums giving a higher firmer pedal. Also required a metering valve (PVM) to the front (the metering valve prevents nose dive).
1966 C10 panel-400 small block/TH 350 combo
Nothing is fool proof to a talented fool!
Popcorn:
Pops at exactly 444 degreese
Expands to 44 times it's original size
Has a 4 year shelf life
Last edited by wild one; 05-02-2007 at 12:37 AM. Reason: Credited the origin of my posted explanation.
wild one is offline   Reply With Quote
Old 05-02-2007, 08:47 AM   #12
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
THATS WHAT MY BUDDY TOLD ME.....MY BRAKE HOSES ARE ALL NEW...
NO PICS OF THE NOVA...TRYING TO GET MY BRAKES GOING....
NO THOSE ARE ADAPTER FITTINGS....
OK ACCORDING TO THIS PICTURE...THE REAR PORT GOES TO THE REAR BRAKES (???)
I SHOULDN'T NEED ANY OTHER VALVE FOR THIS SET-UP..SHOULD I ??
I AM LIKE FRUSTRATED RIGHT NOW.......
SHOULD I TRY SWAPPING THE LINES OR WHAT ??
JOHN
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-02-2007, 09:07 AM   #13
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
ONE MORE THING I FORGOT TO MENTION
THE REAR PORT DRAINS THE REAR RESERVOIR
THE FRONT PORT DRAINS THE FRONT RESERVOIR.....
John
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-02-2007, 11:08 AM   #14
slepysal
slepysal's Avatar
Yea John no valve is need ed for the drum/ drum. Any progress ?
Old 05-02-2007, 12:46 PM   #15
62 short step
I always assumed the rear port closet to the fire wall was always for the rear brakes. I would try swapping to eliminate that. My 2 cents.
Old 05-02-2007, 11:15 PM   #16
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Well I just home..and even before logging on I tryed the swap..and it works now.....
Now my lines look like s#it because I had them bent nicely to the ports...I might need to re-bend a new line sometime.
A drum master is supposed to have checks, but not sure if this one did or not. I didn't check before installing the lines....and I'm not going to pull them right now to check either.
But at least it's work'n !!!!
John
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 05-02-2007, 11:36 PM   #17
62 short step
Cool, glad you got it solved!! Now you can go burn some rubber!!!
Old 05-03-2007, 08:08 AM   #18
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 04-12-2009, 01:01 PM   #19
1966gmc
Why does it taste purple?
1966gmc's Avatar
So the front brakes are the rear port on this set up. Im a bit confused lol
Hello, my name is John and I'm a truckaholic
1966gmc is offline   Reply With Quote
