Old 09-10-2002, 01:20 AM   #1
perrosinpata@aol.com
perrosinpata@aol.com's Avatar
lower control arms
anyone have any 1 ton lower control arms and disc brake assembly?
perrosinpata@aol.com is offline   Reply With Quote
Old 09-10-2002, 11:50 AM   #2
Fast68Chevy
Fast68Chevy's Avatar
i have lower arms, they are same on 3/4 ton as are on SWH 1 ton and probably no different from DWH 1 ton either im sure.,
are you talking SWH or DWH ?
(dual wheel vs. single wheel hub)
if youre talking SWH, then i have all that you need, i dont need these..
Fast68Chevy is offline   Reply With Quote
Old 09-10-2002, 06:17 PM   #3
lower control arms
i have these 2 1/2 spindles that use 73 ball joints but i dont remember if its the upper or lower control arms that change?
Old 09-12-2002, 01:36 AM   #4
Fast68Chevy
upper arms should all work 1/2 to 1 ton and lowers supposedly have larger ball joint case hole diameter on 3/4 and 1 ton than on ½ ton
good luck
Old 09-13-2002, 12:23 AM   #5
control arms
where are you and how much for the disc brake assembly?
