Old 05-01-2007, 09:22 AM   #1
hewlett2002000
hewlett2002000's Avatar
why is my truck overheating?
i am still having my overheating problem. i put a bigger radiator in but still no change. i have replaced my new thermostat. the only thing i can think of is the fact that it has no fan shroud. but i just have a hard time believing that because ive seen alot of cars and trucks run with no shroud. i just hope its not a cracked head or blown head gasket. i can make it almost all the way around the block then it starts getting hot. could it be the water pump? please help.
thanks,
John
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 05-01-2007, 09:31 AM   #2
shaneschevys
Its always something!
shaneschevys's Avatar
Re: why is my truck overheating?
It could be the water pump. Are you loosing water anywhere? Is your engine stock? What part of TX are you from? I might be able to help you out with a shroud.
79 p10 stepvan
72 Short Fleetside
72 Suburban
67 GMC One Ton Flatbed
64 Short Fleetside
57 Chevy 2DR Hard Top
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Member of the patina club
shaneschevys is offline   Reply With Quote
Old 05-01-2007, 09:39 AM   #3
hewlett2002000
i am in fort worth too. between lake worth and saginaw and lake worth to be exact. it is not stock, it had an IL6 in it originally. now it has a 350. the radiator has a few pin holes in it but alumaseal would fix it. that would be great. i have a shop full of parts if you might wanna trade?
thanks,
John
Respect:
Old 05-01-2007, 11:28 AM   #4
slepysal
slepysal's Avatar
Are you sure you are overheating ? I had an older Stewart_Warner temp gauge that showed I was over heating, chaged a few things,only to find it was my gauge. My truck has no fan shroud but is a 6 cly. If you want a fan shroud you can get a universal one from a speed shop. Good luck Sal
slepysal is offline   Reply With Quote
Old 05-01-2007, 12:09 PM   #5
jchav62
1962 C-10
jchav62's Avatar
Maybe the Alumaseal is plugging up your radiator. Have you tried flushing the system? You may have to take it in to be cleaned and repaired.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 05-01-2007, 01:12 PM   #6
hewlett2002000
this radiator is not worth it. but the system never had any alumaseal in it, at least not since ive had it. im getting a 84 chevy for free and somebody told me they put a 88 radiator and shroud in there truck. so im gonna try to put the 84 radiator and shroud in mine. im also gonna replace the water pump while im at it. if that doesent fix it then i got bigger problems. Knock on wood
Respect:
Old 05-01-2007, 06:52 PM   #7
salazar44
65 - Chevy C10
salazar44's Avatar
Does your coolant resivoir have a return? or is it just dumping it? My buddy had a van that didnt have a return so when his van spit the overflow out he was loosing to much coolant and overheating pretty regularly.
VIC
One Repair Leads to Another!
http://vix65chevyc10.blogspot.com
salazar44 is offline   Reply With Quote
Old 05-01-2007, 07:21 PM   #8
19GMC63
19GMC63's Avatar
even though its new, your thermostat still could be defective.
I would test your thermostat.
19GMC63 is offline   Reply With Quote
Old 05-01-2007, 08:51 PM   #9
wild one
Registered.........
wild one's Avatar
Hewlett, before you toss the radiator out of the 84 chevy into your truck, fill it with a couple of gallons of distilled vinegar. I know this sounds funny - but it really does work! Lay the radiator on the ground face down with the radiator cap on, inlet and outlet hoses up. Fill it with the vinegar, then let it sit for at least 24 hours ( the longer it sits, the more it will dissolve ), when you pour out the contents it will no longer be clear but a rather nasty brown/green color.
Be sure to flush the radiator with lots of water, as this will finish flushing the dislodged/loosened gunk left inside. This doesn't harm the radiator in any way, just breaks up all the crap inside and leaves you with clean tanks and a clear(er) core. I have been doing personally for years with good results as a cooling system clean up.
Good Luck,
Pete
1966 C10 panel-400 small block/TH 350 combo
Nothing is fool proof to a talented fool!
Popcorn:
Pops at exactly 444 degreese
Expands to 44 times it's original size
Has a 4 year shelf life
wild one is offline   Reply With Quote
Old 05-01-2007, 09:55 PM   #10
Revin68
Recreational Grease Monkey
Revin68's Avatar
What kind of fan are you using. If its an aftermarket flex fan, trash it. The stock clutch fan is the best especially with no shroud. If you ARE using a stock clutch fan, try putting a new clutch on the front of it, as they do go bad. I know they are not pretty, but they actually are the best for cooling purposes.
Good luck,
Robert
Revin68 is offline   Reply With Quote
Old 05-03-2007, 09:50 AM   #11
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
hewlett2002000, check your water pump first. start your motor when cool remove the radiator cap fill water level to where you can see it then goose it a little. you should see the water flowing strong in the radiator. also there is a drain hole on the bottom of the water pump. if it is stained or rusty like water has been leaking pump no good.
gulfcoast66 is offline   Reply With Quote
Old 05-03-2007, 10:02 AM   #12
Chevy Fleetside
Chevy Fleetside's Avatar
You are probably running a temp sender from that 350 and not the original L6. The resistance is differnt in that sender. I had that problem and had to use a 32 ohm resister to get it right and it still wasn't right, could have used a 33 even... Best way to check is to run the engine with the cap off and look to see if the coolant flows through the radiator when the thermostat opens and stick a thermometer in there and take areading that way.. But like suggested above, check and make sure the thermostat is working. Take it out and stick it in a pot of boiling water and see if it opens..
Chevy Fleetside is offline   Reply With Quote
