Old 05-01-2007, 12:27 PM   #1
Roper
Larger fuel tanks
My 81 full size long wheelbase truck has two 16 gallon tanks mounted on each side of the truck.
Im thinking about replaceing them with factory 20 gallon tanks.
My question is are the 20 gallon tanks a direct bolt on. Will the hangers on the frame have to be moved to make the tank straps line up.
I guess I will need shorter filler hoses but besides this is it basically I straight bolt on job without modifications?
Also I havnt taken my old tanks off yet but everything looks rusty. I know im going to need new tank straps and rubbers but im wondering what else im going to end up replaceing. Example lock ring and o ring for the sending units?
Roper is offline   Reply With Quote
Old 05-01-2007, 02:42 PM   #2
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: Larger fuel tanks
I have the same setup. I was wondering the same maybe someone will chime in and answer this. But i do think it just a bolt in cause from my truck to mu other with the 20 gal looks the same.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 05-01-2007, 06:23 PM   #3
78Chevy
78Chevy's Avatar
I'm no expert by any means, but I think that it would be easy to change from a 16 gal to a 20 gal if you have a long wheel base. We have two long wheel base truck, both with dual tanks and they are 20 gal. I don't believe that it would work on a short wheel base. I wish it would though!
Al
97 K1500 Tahoe 5.7 Stock "Driver"
78 swb C10 Silverodo/ 350cu. dual Flowmaster's, MSD cap, and wires. "Project"
LONG LIVE AMERICA!!
78Chevy is offline   Reply With Quote
Old 05-01-2007, 06:46 PM   #4
Srubydo1986
The Crazy Machanic
mine a long bed with 2 16 gal tanks
newest additions
Old 05-01-2007, 07:34 PM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Why don't you install a 45 gallon tank?
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 05-01-2007, 08:00 PM   #6
Srubydo1986
The Crazy Machanic
me to lazy him probley like the sattle bag setup.
newest additions
Old 05-02-2007, 10:46 AM   #7
Roper
I have dual exhausts because my truck is lifted <front driveshaft>and the dual exhaust would be in the way.
Thanks everyone
Old 05-02-2007, 10:07 PM   #8
SanitysBane
If you have a long bed, a 20 gallon tank will bolt right in.
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 05-03-2007, 09:36 PM   #9
Roper
Well I went into town today to buy some parts. Got talking to the mechanic at the GM dealership. He said he put the larger tanks on his own 81 long box years ago. Said he cant remember all the details except it was a pain.
#1 He said that unless you have the box off the truck itas a real pain. Example unhooking up the wires to the sending unit.
#2 He said with the longer tanks the frame brackets are in the wrong spot. He couldnt remember if he had to just move the back brackets or get replacement ones for a 20 gallon tank.
On the plus side he said the frames are all drilled for the new bracket location.
Anyway im thinking the heck with it. Im going to put a flat deck on my truck anyways.
Right now I have a huge third tank in my bed but its not DOT approved and it doesnt have a fuel gauge. I noticed in the parts store that they have bed tanks<probable 60 gallon> that are diamond alunimun and DOT approved for gas. These tanks mount right in the bed of your truck. Im thinking when put the deckl on my truck I will buy one of these bed tanks and then take off my factory tanks.
With the factory tanks gone I can build custom running boards that I can bolt directly to the frame <think strong>and those old fuel tanks wont be in the way.
Old 05-03-2007, 10:28 PM   #10
SanitysBane
You don't have to get new brackets, I went from a 16 gallon tank to a 20 gallon tank on my '83 long bed and all I needed was a 20 gallon tank and the filler hose.
'88 K5 Blazer
Old 05-04-2007, 10:02 AM   #11
Roper
Did you have to move the back bracket? Thanks.
