Engine Codes
I Need help with the engine codes on block.
VO114UFC TGF714834 |
The Older Generation
Re: Engine Codes
You can try here.... http://www.mortec.com/castnum.htm Usually these are the casting numbers on the back of the block on the drivers side. LockDoc
Re: Engine Codes
I forgot to mention also; above the message area of the main screen, on the right side, there is a "Search This Forum" button. If you click on it and type in engine codes you will find a few threads on the subject. LockDoc
member #16
![]() Join Date: Dec 1999
Re: Engine Codes
You can find the suffix code here. UFC suffix
UF 1969 307 tur hydro 200 2 K-20 & 25 UFA 1980 350 van, bus, a/t, Cal L LS9 165 4 C-10 & 1500 UFB 1980 350 van, bus, m/t, Cal M LT9 165 4 C-30 & 3500 UFC 1980 350 van, bus, a/t, Cal M LT9 165 4 C-30 & 3500 UFD 1980 350 van, bus, m/t, Cal M LT9 165 4 C-20 to 3500 UFF 1980 350 van, bus, a/t, Cal M LT9 165 4 C-20 to 3500 UFH 1980 350 van, bus, m/t, Cal M LT9 165 4 C-30 & 3500
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
