Old 05-01-2007, 05:31 PM   #1
Roper
Fluid Differential Capacities 14 bolt
I just checked the oil level<added until full> on my recently rebuilt <3000miles ago>14 boltFF. I had to add about a quart and a half!
Was wondering if there was any oil in it? How much do they hold? 3 quarts??
Its not leaking so when they rebuilt it they didnt put enough oil in it.
Wonder how long that rear end will last? Mostly only been using it on short trips<under a couple of hours and under 60MPH> this winter. Plus im in Alberta and despite the Al Gore claims were not having any global warming going on up here.
Roper is offline   Reply With Quote
Old 05-01-2007, 06:54 PM   #2
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: Fluid Differential Capacities 14 bolt
My trucks 10 bolt used about 3 so urs should be a 4 cause of it very large size. but idf you need an exact go to autozone web site it can tell you or call them they can tell you from there computer.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 05-02-2007, 10:39 AM   #3
Roper
Im thinking that rear end is alright then if they hold that much. I will do a autozone web search and double check the capacity. I rechecked my rear last night when I got the truck rear end perfectly level and about a half a quart came back out so it was really only down a quart.
