05-01-2007, 06:08 PM | #1 |
exhaust question
I'm in the process of putting a dual exhaust system that dumps in front of the rear tires on a lwb 72. I was hoping to include a crossover but my concern is if I choose that option the system will have to be dropped below the frame which isn't an option. All I want to see is the tips dumping at the tires. Has anyone been able to put a crossover and have the system tucked under the truck so you can't see it from the side. Pics would be great
1972 c-20, 350/350, dana 60 w/456 gears(no Posi) Last edited by TotalChevy1; 05-01-2007 at 06:08 PM. |
05-01-2007, 07:48 PM | #2 |
Parts and more parts
Re: exhaust question
There was a truck on the 2000 Power Tour that had his exhaust running throught the frame at the front under the floor boards and then run along the outside of the frame and turn out at the wheel wells. He had built round tube gussets into the frame in that area for support.
05-01-2007, 07:51 PM | #3 |
Insert Title Here
but thats not giving him a crossover pipe
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
05-01-2007, 07:56 PM | #4 |
Insert Title Here
here is mike nutts truck
05-01-2007, 08:05 PM | #5 |
Keep On Keepin' On
Is that 2.5 or 3 inch pipe...really like how it is dumped behind the tires..I am going with 3/5 drop...anything I need to look out for? think I will need a diff trans crossmember??
07 Avalanche Z71 92 Mustang 5.0 GT (Triple White w/ 53,000 miles) 72 SWB Chevy w/ PS, AC, 350/350 Current Project ....In paint shop getting body/paint work done (Corvette Velocity Yellow)... http://67-72chevytrucks.com/vboard/s...d.php?t=157669 |
05-02-2007, 04:06 PM | #6 |
ttt...any pics from lwb with exhaust in front of tires with a cross over. Any pics would be appreciated. The muffler shop I'm going to use said it can't be done.....
1972 c-20, 350/350, dana 60 w/456 gears(no Posi) |
05-02-2007, 06:55 PM | #7 |
It can be done. I don't have any pics of my old system but I had it come from the headers outside the frame rails under about where the seats are then out in front of the tires.
05-02-2007, 06:58 PM | #8 |
Whoops I found a pic. Look close and you'll see the tip coming out underneath the step in front of the tire.
05-02-2007, 08:19 PM | #9 |
05-02-2007, 09:09 PM | #10 |
69fatmotor
that is 2 1/2" pipe , you could run 3" , but it will get close with a 5"drop . mine has 7"s of drop right now . make sure that the bed is mounted , shocks,etc. space gets tight quickly , so make sure every thing is were you want it. good luck , mike
