Old 05-01-2007, 08:16 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
could cam be wiped but are lifters ok?
i just put together a 350 and i got it up and running. the engine idles fine but only bogs when i drive it over 35 or try to get on it. the carb is also new and its vortec heads are new. everything is new and the timing is set good as well. i took all of the lifters out and the all look good. is it possible that the lifters be alright by the cam be slightly worn?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 05-01-2007, 08:22 PM   #2
manimal
manimal's Avatar
Re: could cam be wiped but are lifters ok?
Did you mark what hole the lifters came from? If you think the cam is flat, then replace them both. DONT REUSE USED LIFTERS ON NEW CAM!!!!
-Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 05-01-2007, 11:18 PM   #3
jhow66
jhow66's Avatar
Need more info:
1--time set at what?
2--new carb-used-rebuilt?
3--bogs above 35-how? (when you step on it or just cruising?)
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 05-02-2007, 12:44 AM   #4
jsbgump
Gone Fishing
jsbgump's Avatar
Never re use lifters on anything.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 05-02-2007, 08:52 AM   #5
chipflyer
chipflyer's Avatar
You can reuse them if you want to go through the same problem again in a couple months.
No, do not reuse them!
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 05-02-2007, 10:48 AM   #6
Overkill67
Also check that the vacum advance is working properly. Points or HEI? What is the cfm of the carb?
Overkill67 is offline   Reply With Quote
Old 05-02-2007, 12:29 PM   #7
crm318
crm318's Avatar
i realize that this post may make me seem like i dont know about the do and donts about cams. i know that you cant reuse lifters. i have all of the valvetrain on a tray to fit back into the assigned lifter bores. it just seemed that the cam might be wiped by the way it was acting. the engine is a vortec headed 350 with a newly rebuilt quadrajet, new accel HEI distributor, timing set at 10 degrees (have experimented with diffrent settings). it accelorates up to 35-40 nicely under cruising conditions. after that it starts to run rough. full throttle is out of the question. the lifters look great so i assume that the cam is ok. when i get it buttoned back up, i plan to take the quadrajet off of my running truck and put it on to see if its a carb problem. could it be unadjusted valvetrain? i tried to do the hose in ear adjustment but it seemed that there was a slight ticking on all the rockers no matter how much i tightend them.
1972 Cheyenne
Old 05-02-2007, 01:41 PM   #8
albertarose
albertarose's Avatar
ttt move to top so next viewer sees first ?
albertarose is offline   Reply With Quote
Old 05-02-2007, 01:42 PM   #9
albertarose
you need new lifters for your new cam...anyone else ?
Old 05-02-2007, 03:22 PM   #10
bryanw1968
bryanw1968's Avatar
The problem doesn't sound mechanical. Are you running roller tip rockers?
If so, they're just going to be noisey no matter what you do. Also, certain cams that are very aggresive slam the exhaust valve down hard and it will make the same "loose rocker" noise.
What cam are you running? 10 degrees may not be enough timing. Also, there is a good chance that your vacuum advance may not be right. Which port on the carb do you have it hooked to? It should be connected to the port that has NO vacuum at idle. Otherwise if you have it connected to constant vacuum it will be pulling timing into your initial timing.
Got any pics?
Good luck,
B
bryanw1968 is offline   Reply With Quote
Old 05-02-2007, 03:26 PM   #11
crm318
crm318's Avatar
the cam is .440/.440 212/212. i meant to say that ive run it with as high as 14 degrees and as low as 10 degrees.
1972 Cheyenne
Old 05-02-2007, 03:30 PM   #12
crm318
crm318's Avatar
i dont have any pics right now because the top half of the engine is off. i will take a few pics when i get it all back together.
1972 Cheyenne
Old 05-02-2007, 03:58 PM   #13
bryanw1968
bryanw1968's Avatar
Do you remember how you had the vacuum advance hooked up to the carb?
What kind of vacuum are you reading at idle? With a cam like that you should have over 15 inches at idle.
Old 05-02-2007, 04:08 PM   #14
seanu
Too many projects!!!
seanu's Avatar
Sounds like a carb problem to me...had something similar when I put to much carb on a SB 350 I had...
It seems to me that if it was a cam or lifter problem..since they are completely mechanical..that it would be present at any RPM and at any speed...that fact that it is only under certain curcumstances...makes me think carb..or possibly spark.
just my .2¢
Sean
1995 Buick Roadmaster Sedan
2004 Chevy Trailblazer 5.3L V8
1963 Chevy Biscayne 4D Sedan
1971 Chevy C10 (now have 70 cab & frame)
1968 Chevy C10 (parts for the 70)
1991 Oldsmobile Custom Cruiser (Chevy 355 motor)
1937 Pontiac 8 4D Touring Sedan (in pieces)
Jacksonville, Florida
seanu is offline   Reply With Quote
Old 05-02-2007, 04:21 PM   #15
riche
New Member
I would lean towards the carb, fuel pump or filter. If a cam lobe was wiped I would have expected you to complain about backfires or running on after the engine was turned off. The only other thing that bothers me is this comment
"could it be unadjusted valvetrain? i tried to do the hose in ear adjustment but it seemed that there was a slight ticking on all the rockers no matter how much i tightend them"
If you suspect the valvetrain adjustment I would seek a good valve adjustment procedure to eliminate that variable. I have never used a hose in my ear to set valves. There is always ticking, but there is a distinct difference between clacking and ticking.
1969-72'ish C-10 SWB Step
1997 Chevy Z71(sold)
2005 Chevy Crew Cab
riche is offline   Reply With Quote
Old 05-02-2007, 04:30 PM   #16
Billla
Billla's Avatar
When you say "put together" you mean overhauled?
If the idle is fine, I wouldn't suspect a worn cam lobe right away. It happens during break-in, but not all that commonly. I would double-check the valve adjustment, then look at the ignition and timing and finally the carb.
Billla is offline   Reply With Quote
Old 05-02-2007, 06:50 PM   #17
bryanw1968
bryanw1968's Avatar
Right, timing first, then adjust carb.
What do your plugs look like by chance and what plug are you running?
Old 05-02-2007, 07:15 PM   #18
crm318
crm318's Avatar
plugs and wires are new. the plugs are autolite 25s. i have heard that vortec heads take a specific plug, but i use the same autolites on all my small blocks.
Just to clear a few things up:
1. The carb is a 750cfm Q-Jet rebuilt recently, and run successfully on another motor for three months.
2. The fuel pump is electrical due to the year of the short block. The short block is out of an 89 silverado, and is rebuilt. I usually have shortblocks that take mechanical fuel pumps, but this is a first. My fuel pump is new and pumps at 4.5 psi.
3. There is an inline fuel filter placed before the fuel pump, and mounted at the tank as directed.
4. The HEI, plugs, wires, coil, etc are all new.
5. Now that the cam and lifters look ok, I'm going to readjust them properly, and... I'm not sure what the next step is.
To retract my prior statement, the vehicle bogs and sputters any time it is driven. When gas is given, it bogs and sputters. More when more fuel is delivered, but it's constant unless left at an idle.
1972 Cheyenne
Old 05-02-2007, 07:31 PM   #19
rage'nrat638
rage'nrat638's Avatar
yes vortec heads require a longer threaded plug or the plug is firing in the threaded hole and
not in the chamber where it's supposed to be
check the vortec's what to know in the FAQ section for the correct plug from AC DELCO that may be your problem
http://67-72chevytrucks.com/vboard/s...ghlight=VORTEC
Special Spark Plugs For The Vortec Heads
R44LTSM, set of 8
MR43LTS, set of 8
P526S Accel U-Groove “SHORTY” Double Platinum Header Plugs approximately 3/16" shorter then R44LTSM plugs, set of 8
rage'nrat638 is offline   Reply With Quote
Old 05-02-2007, 07:47 PM   #20
crm318
crm318's Avatar
Which plug is suggested. I see three listed. Let's rule out the accell plugs because spacing is not an issue. So...
R44LTS?...or...
MR43LTS?
1972 Cheyenne
Old 05-02-2007, 07:52 PM   #21
rage'nrat638
this is what i am running R44LTSM
m stands for metric
went outside and took a picture
Old 05-02-2007, 07:55 PM   #22
rage'nrat638
Old 05-02-2007, 10:31 PM   #23
gator2511
gator2511's Avatar
When I set my timing at 10 BTDC the truck runs ok but when I hook it to the full vacuum port on the carb and let it sit at 20 BTDC at idle it has much better throttle response and runs great. Right now I'm at 8 BTDC initial and full vacuum port and I have a total of 38 Degrees of advance at 3000 rpms. As you accelerate the vacuum goes down and the vacuum advance drops off as the mechanical starts cutting in. I'm not saying that is your problem but its easy to switch the vac can to the other port and see what it does.
gator2511 is offline   Reply With Quote
Old 05-03-2007, 03:30 PM   #24
crm318
crm318's Avatar
This may be a dumb question, but I have to ask. I picked up a set of R44LTSM plugs today, and they're all pre-gapped to 40. What is the appropriate gap for these plugs? I just want to get it right the first time.
1972 Cheyenne
