05-01-2007, 10:03 PM | #1 |
Senoir Member
Putting the firewall together.....
Thought these should be seperate. I'm putting things back together during this frame off resto....and need advice on what order to put things back under the dash. Looks like the steering column goes in first then the insulation pads, then everyhting else. Any advice?? Thanks again, Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 |
05-02-2007, 02:32 PM | #2 |
Senoir Member
Re: Putting the firewall together.....
ttt
05-02-2007, 04:33 PM | #3 |
ttt
Avatar is a pic of "Before"... Just wait.. ---------------- 1969 Fleetside: Shortened frame for SWB, ECE 4-6 drop. ECE SS tank. All new ECE suspension. Rebuilt 12 bolt 3:73 with Eaton Posi. Front and rear disc brakes. Ramjet 350 and 700r-4 trans. 20" Centerline wheels with Kumho 295/45/20 tires (I hope they fit). Progress pics: http://s44.photobucket.com/albums/f2...uck/?start=all ---------------- Seriously... It's nothing a large dose of cash can't fix... Right? After all, I can't take it with me when I go... Just gotta have enough to get there!!! |
05-02-2007, 08:03 PM | #4 |
Work from the top down inside out. Dash pad, insulation, Wiring harness, speaker for radio, light switch, wiper switch, radio ,A/C duct work and vaccum lines, oil lines guage cluster steering column, vents,air control, glove box, glove box door, ash tray, knobs. Stand back and look- remember these trucks were assembled on a line rather quickly so there is a sequence to it all- build manual also helps.
05-03-2007, 07:21 PM | #5 |
Senoir Member
Thanks for the help. Greg
