Old 05-01-2007, 10:40 PM   #1
62chevy302
hillbilly
62chevy302's Avatar
62 to a 66
im switching a 62 cab to a 66 frame any ideals or trouble spots i will need to focus on and also i have the 283 in it and i want to switch it to a five speed does any body know if a s-10 2.8 transmission will work it has the removeable bellhousing and i have a bellhousing for it i belive im switching from a 350 turbo. any help would be great and you guys seem awesome. well thanks in advance. oh yea firts post. thanks,
john miller
62chevy302 is offline   Reply With Quote
Old 05-02-2007, 06:52 PM   #2
thekid54
Re: 62 to a 66
Front cab mounts are different. Do you have the '62 frame? If so, remove the front cab mounts from the '62 frame and weld them on the '66 frame. That's what I did when I put my '62 cab on a '63 frame.
thekid54 is offline   Reply With Quote
Old 05-03-2007, 09:27 AM   #3
62chevy302
hillbilly
62chevy302's Avatar
Re: 62 to a 66
yea the truck is still setting on the 62 frame is there any thing else different? i was going to switch the front mounts over. i was going to switch the arms and spindles over so i can go to disk brakes but i dont know what years i can get them from.
Old 05-03-2007, 01:23 PM   #4
thekid54
Re: 62 to a 66
I swapped in a '73-'87 front crossmember on mine. I know '71-'72 will also work.
Old 05-03-2007, 03:37 PM   #5
62chevy302
hillbilly
62chevy302's Avatar
Re: 62 to a 66
this thread is sticky and i dont want switch crossmenbers i wonder if the a arms are the same
http://67-72chevytrucks.com/vboard/s...d.php?t=171667
Old 05-03-2007, 06:42 PM   #6
thekid54
Re: 62 to a 66
Yeah, you can just swap the arms on the '66 frame.
Old 05-03-2007, 07:33 PM   #7
jchav62
1962 C-10
jchav62's Avatar
Re: 62 to a 66
I think you the spindles from a 71-72 will bolt up to 63-66 A-arms. Correct me if I'm wrong, just what I've heard. My 62 is has a 73-87 front crossmember on the original frame. It's been on there since the late 70's...works great..Good luck with your project!!
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 05-03-2007, 08:42 PM   #8
62chevy302
hillbilly
62chevy302's Avatar
Re: 62 to a 66
i guess i just need a 71- 72 2wd 1/2 ton with disc brakes that should be easy to find. how bout the 5 spd?
Old 05-06-2007, 09:25 PM   #9
62chevy302
hillbilly
62chevy302's Avatar
Re: 62 to a 66
no luck yet on the brakes i might have found a 5 spd. would a mig welder do the welding to the frame ? if so where should i get one cheap?
-1962 C-10
Old 05-06-2007, 10:07 PM   #10
stacerbob
BODY SHOP SUPPLIES INC.
stacerbob's Avatar
Re: 62 to a 66
was the 62 not torsion bar front???
stacerbob is offline   Reply With Quote
Old 05-07-2007, 12:15 AM   #11
stepside66
stepside66's Avatar
Re: 62 to a 66
yep its torsion bar get ahold of a plasma ccutter and cut the trann member out and order in one from CPP and bolt the tranny up that way and you can have front discks and coil springs
stepside66 is offline   Reply With Quote
Old 05-07-2007, 01:52 AM   #12
1963chevyshort
New Member
1963chevyshort's Avatar
Re: 62 to a 66
If you still use the your 62 or 66 control arms and want to use the 71 to 72 spindle remember to change the ball joints on the control arms since that would be the only difference.
Anthony
63 chevy stepside SWB
57 chevy 2dr hrdtop belair
1963chevyshort is offline   Reply With Quote
Old 05-07-2007, 01:12 PM   #13
62chevy302
hillbilly
62chevy302's Avatar
Re: 62 to a 66
so if i get 71-72 ball joints and spindles it will go all together with disk brakes? what about 73-87 a-arms.
-1962 C-10
Old 05-07-2007, 04:15 PM   #14
jchav62
1962 C-10
jchav62's Avatar
Re: 62 to a 66
About the 5 speed. I read somewhere that the one that will work is a T5 that was off a 4.3 vehicle. Like an S-10 or an Astro van.
Joseph Chavez
Old 05-07-2007, 06:30 PM   #15
62chevy302
hillbilly
62chevy302's Avatar
Re: 62 to a 66
i think i know where one is but just waiting to see if i can get it. and i looked at my frame today the rear mounts are differnent too? right?
-1962 C-10
