05-01-2007, 11:32 PM | #1 |
Dash Removal?
I was wondering how you remove the dash? I got the 3 bolts on each side, but I cant see what else is holding it on there. Any help?
05-01-2007, 11:36 PM | #2 |
Re: Dash Removal?
It is welded all along the windshield!
Kevin LFD Inc. |
05-01-2007, 11:41 PM | #3 |
Re: Dash Removal?
Ah ****. So if im getting it sandblasted I gotta cut it? or leave it in or what?
05-01-2007, 11:42 PM | #4 |
Re: Dash Removal?
Yep! Why do you want to remove it?
05-01-2007, 11:46 PM | #5 |
Re: Dash Removal?
I was under the impression I had to remove everything when getting that done.
05-01-2007, 11:46 PM | #6 |
TOTY 2006
Re: Dash Removal?
Sorry, way to slow on my part in this thread....
Yup, many spot welds all along the bottom flange of the windshield. Option one - remove winshield, drill out spotwelds (or use spotweld cutter), remove old dash, install new dash and reweld flange, reinstall windsheild. Option two - remove the dashpad, and cut dash all along the oval holes (that you will see once the dashpad is removed), do same to new dash and weld new dash along each cut you made (when removing old dash)... Last edited by John Fabris; 05-01-2007 at 11:47 PM. |
