![]() Join Date: Mar 2003
Which wheel do I start and finish with when bleeding the brakes? Thank you All
I forgot, Is there a way to bleed the poportioning valve or will it bleed when I bleed the system? Thank you
Re: Brake bleeding?
start on the 1 furtherest away from the master cly .. back pass side, then drivers rear, pass front then drivers front .
1969 rs 1966fastback 1969swbc/10 2006gt 1972swb4x4 |
Re: Brake bleeding?
Start with the right rear then left rear then right front then left front.
usually pro valves have a bleeder on the front of them.
![]() ![]() ![]() 67 C10 SWB 350-Turbo 400 tranny-Disc brake "Those who live by the sword get shot by those who don't" |
How do I bleed the proportioning valve and do I bleed the brakes first or the valve first? Thank you
Re: Brake bleeding?
i start with the left rear which is the longest run of tubing from the master cylinder then the right rear right front and left front// you also need to hold the pin in on the combination valve with a special tool (some use a cclamp) while bleeding brakes
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 05-03-2007 at 04:42 PM. |
what kind of clamp do I use to hold the pin in ?and Does the pin stay pushed in while I'm bleeding the brakes and when do I release the pin? Thank you.
1969 Short, Fleet, and Beat
Re: Brake bleeding?
This is interseting. I thought you first bench bleed the master cylinder then do the wheel furthest from the master cylinder ending with the wheel closest to the master cylinder as described. Never knew you had to bleed the proportioning valve.
Does the proportioning valve need to be bled? My brake pedal is going to the floor and very slowly coming back up,and the rear brakes are locking up,so the truck won't move foward or backward,so I'm suspecting a master cylinder or proportioning valve,but thought I'd try to bleed the brakes first and the proportioning valve. When Should I bleed the the proportioning valve at the same time as I'm bleeding the brakes and what tool or clamp do I use to hold the pin in? I sure appreciate the help.Thanks guys.
Re: Brake bleeding?
by holding the pin in on the combination valve your preventing it from diverting the pressure to the sealedpart of the system if you dont hold it in in theory the valve wont allow fluid to flow to the part of the brake system your trying to bleed// most people just use a 4" c clamp and after all 4wheels are bleed its released
![]() Join Date: Oct 2005
Re: Brake bleeding?
Hey I just went through the same thing and I found that my wheel cylinders were bad on the rear. Also I didnt hold in the pin on the proportioning valve, It prob. would have been better to do so. I also had to replace the hose for the rear brakes. the one that runs from your hard line down to the axle. Mine was completely closed off. I also went to the drivers side rear first because on the 72 with coils this wheel is farthest away because of the routing of the lines.
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod. ![]() |
One other?,Where is the pin on the proportioning valve.My brake lines and wheel cylinders are all new. The proportioning valve is origional and the master cylinder is 3 1/2 years old with only about 3,000 miles on it. Thank you
#13 |
Re: Brake bleeding?
its on the front sometimes covered by a rubber boot
#14 |
Post Whore
![]() Join Date: Feb 2000
Re: Brake bleeding?
You can start front or rear - doesn't matter as they are fed separately.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
