overflow canister
Does anyone have an idea for a radiator overflow canister that will work good on our trucks. I have a 72 with air. any suggestions or pictures would be appreciated.
Old Skool Club
![]() Join Date: Jun 2001
I don't know who makes it, but I am planning to use one of the street rod-style aluminum tanks that fit vertically, whereever you choose to mount it. It just looks good, and has a knurled screw-off top.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Has anybody had any problems with your trucks on hot days with A/C on and the radiator pushing water out the overflow onto the ground? I have been running the a/c constantly here recently and have had the problem a few times. I feel like I have to constantly check the water levels.
Let me get my flame suit on..... there....
I used an overflow tank from an Explorer. It comes married to a windsheld washer reservoir with a built in pump. Changed the wiper switch to activate the washer pump on the reservoir instead of the goofy-ass 4 pulse pump GM puts on their wiper motor .
72 GMC K20, 454, TH350 00 GMC Yukon 66 Ford Bronco |
Gasser
I used a Jaz 1 Quart catch can. It is plastic ( in several different colors) with 1/4-20 brass inserts. I just took two pieces of 1/8x1/2 aluminum flat stock, bolted one end of these to the catch can, brought the other ends together, bolted these ends together through an existing hole in the battery box.
:thud 70 sstep tubbed, Muncie, double hump, snowflake, |
summit has one of there own brand thats pretty trick and cheap!!!
Ken Lyons, Slippery rock pa 68 short step 327 t10 4 gear 72 2wd blazer project 70 lwb 305/700r driver 78 caprice project 02 cavalier D.D ( hate it!!) |
Old member
I used a Monty Carlo one and it works great right behind the battery, don't even have it tied down. You can see it on picture trail photo's are better yet I will post it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
its all about the +6 inches
I have an extra windshild washer bottle and bracket. I'll be mouning it under the battery tray so it doesn't clutter the engine compartment.
I'm thinking of putting the actualy windshil;d washer bottle under the other battery just to try to clean up the underhood. Just tossin out ideas. |
I have one of the streetrod style ones. Its a 24" long and 3" diameter stainless steel cylinder w/ a machined aluminumn screw top. It looks cool and for the most part works, but on some really hot days when Im driving it really hard the radiator will puke out more than the tank can hold. Doesnt really affect cooling but then when it cools down theres that much less coolant in the radiator. If you could find a streetrod style one w/ more volume, thatd be great but if not Id go for a OEM style plastic one. You could probably find a fairly cool looking one in a late model car of truck.
No, Its not a 454 |
I found a good fit from an 82 Camaro. Its a big tank and the back is contoured close enough to fit on the inner fender of the truck with just 2 screws.
1970 GMC 1500 Custom Original 350/TH350 Victoria, BC, Canada You can wish in one hand and crap in the other. See which one gets filled first. |
B4 we transhed our 84 t-bird my boy slavaged the overflow from it while I was a t work. He installed in on the fron driver side corner and it fit like it bleonged there. Ed ke6bnl
Ed ke6bnl Agua Dulce 70 S.E. Los Angeles 70 Chevy short bed 1948 F3 ford pu 1949 F1 stock V8 flathead 3 on floor 1950 F1 pu street rod 1948 F6 Ford Dually/350sbc no bed stock trans&rear 1972 El Camino 4" chop 1953 Chevy 3100 2b daily driver 1970 SB 4X4 400ci 6in lift |
English Chevy Owner
I have a 1 litre old plastic oil bottle with a hole cut in the lid for the pipe that the previous owner fitted, tucked away down behind the headlight, looks like crap but does the job and is pretty well hidden, will get around to replacing it one day. Jegs have a nice selection of aluminium cans or I may just visit a junkyard and find something.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
#13 |
The one I am using now is also from a G-body car like the picture above. I tried to screw it in, but it didn't match the contour of the inner fender and ended up breaking. Thanks for all the ideas!
#14 |
![]() Join Date: Jan 2000
A friend of mine uses a large Fosters Lager can attached to the radiator support with nylon ties and a overflow hose stuck through the can tab hole. Crude but effective.
#15 |
I use an old windshield washer bottle and it fits in the corner of the fender behind the battery.
Jim |
#16 |
i need to get one so i can go to the track but i dont know where to put one. i wanna get either a summit/jaz one or a street rod (nicer looking) one but i dont know where to put it. post more pics
68 short step, 406/700r4, 9" w/discs. |
#17 |
English Chevy Owner
The beer can idea gets my vote, only trouble is if you have to drink Fosters Lager!
