05-02-2007, 05:14 PM | #1 |
wiw ? blazer parts
i have parted out alot of trucks but only 1 4wd so i need a little help on prices.
i found a 70 cst k-5 blazer f/s and before i buy it i need to no what some of the parts are worth. the guy that has it quite driving it about 15 years ago because he had to many auto's on the road at that time. everything was working good at that time but alot of the parts may need rebuilt now. here are some parts i would like to get fair pricing on. ft.and rear end he said they are orig. and it stayed in 4wd till you got past 20mph. double wall top about a 7 out of 10. auto. trans not sure if its a 350 or 400 np205 transfer case. it had a orgi. 350 but rear seal went bad and he had a good 307 so he put it in . i think the drive lines are worth around $125.00 for the pair. thanks for any help on this. |
05-02-2007, 05:20 PM | #2 |
Re: wiw ? blazer parts
The transfer case around $250-350 (maybe more)...in good shape.The adapter plate,another $150 +-.Tranny is probably still the turbo 350.Does it have a chrome shifter handle and still have the t case shifter knob?If it does,I might be interested in the shifter knob.The axles maybe $150 a pair if it has 3:73s.
05-02-2007, 05:24 PM | #3 |
4wd shifter is there it's black with black knob. thanks for the info.
05-02-2007, 05:54 PM | #4 |
Hey Bill, I picked up an NP 205 for a hundred up here, so I think it depends on the area. Also had a 203 thrown in on a deal, buying a TH400, paid a hundred.
Complete axles are around a hundred for each. Good tubs could be around 500-750 Dbl wall top 200-500 Solid rust free frame might be worth a good buck...jmho
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
05-02-2007, 06:01 PM | #5 |
The LuvShack Garage
I sold a double wall top for $50 3 years ago, bought another this year for $50,
but that did NOT include the hatch, a good hatch can bring in some big bucks.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
05-02-2007, 09:44 PM | #6 |
thanks again for the info. best i remember the hatch has damage on i side. what about the rear side wall brackets that holds up the rear interier value.
05-02-2007, 09:57 PM | #7 |
Just let me buy the carpet strips if they are in semi-decent shape! The PO for mine was supposed to find them and get them to me and never did, every once in a while I talk to him and ask, but it's been more than 2 years already.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
05-02-2007, 09:58 PM | #8 |
I took two decent double wall tops to the dump a couple years ago. Not saying they aren't worth anything, but I wouldn't add anything for the top to the purchase price just in case. Those brackets for the interior brackets are worth $5 - $10 per bracket.
Have you seen the Blazer parts going on Ebay lately?? Talk about TOP DOLLAR!!
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
05-03-2007, 10:18 AM | #9 |
computer illiterate
im not sure about the staying in 4wd until it gets to 20 but maybe that is because it has an np203 im not sure but it sounds fishy to me. if it is a th350/np205 i would say 350 as a combo. if it is th400/np205 i would say 5-00 as a combo
as for the axles i sold my last 2 sets for 450 a set double wall top 50-100 if your lucky enough to find someone that wants it 307 is worth scrap weight on a second note if the rear floor is 100% rust free ill give you 200$ for it
72 2wd blazer 72 swb 4x4 |
05-03-2007, 11:47 AM | #10 |
Parts Hunter
This is most likely going to kill you guys but I found a relatively rust free 72 blazer out here in CA in a junk yard. It will end up being crushed and I'm looking for stuff to chop off it to make some money. Bed floor is mint front to back but alot of work to remove by itself. The top is junk, and lift hatch is junk. No interior, no engine, no rear drive shaft. turbo 350/np 205, windshield frame looks to be rust free, bondo in rockers, and a little bit in the bed sides. I was thinking about saving the entire cowl down to the floor (factory air) and taking the entire rear clip from where the floor dips up to the back seat area back. Frame is rust free but front x-member is cut. Is there anything that I missed that I probably should not cut up?
1968 Chevelle 300 DLX (350 4 speed) 1984 GMC 2500 6.2, 700r4 work truck 1967 GMC Custom (was 6.5 Turbo Diesel powered) My ebay Store: http://stores.ebay.com/The-Musclecar...3aFQ3aSTQQtZkm My website:http://themusclecarshop.net/ 1967 GMC 6.5 TD conversion build:http://67-72chevytrucks.com/vboard/s...d.php?t=290922 |
05-03-2007, 12:24 PM | #11 |
Bill, put me in line for he trans/tc case.
SEMA Network- Protect our Hobby! 71 C30 in pieces, starting to come together. Click here for A Place For Tennessee Truck Enthusiest To Meet |
05-03-2007, 12:39 PM | #12 |
thanks guys . woodridge if i get it i will let you know.
05-04-2007, 08:43 AM | #13 |
Thanks Bill
