![]() Join Date: Sep 2005
ignition timing ?
okay i am putting my 305 back together i got a new hei distbator for it what should i set the timing for an hei at?
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
![]() Join Date: Mar 2003
Re: ignition timing ?
I would initially set at 6 btc and see how it runs---may want to change it later depending on power and possible pinging
Parts and more parts
Years ago, I ran mine at 10 degrees BTDC at first and then went to 12 degrees. It worked well and had no issues. I now set the TOTAL advance (using a timing light with the advance feature) and the initial settles out where it needs to go.
i am wanting to try and get as close to run as plossble for the 20 min 2k brake in
