Lost amongst the CORN
Invisible weld seem video
A member of another forum I visit posted a short video on how to do a invisible weld seem.
http://www.youtube.com/watch?v=wntAnn4EowM
Currently working on How To Videos and custom metal 70 Chevelle gettin Sliced and Diced Anything But STOCK 70 Chevelle SS455 not a typo its a BUICK BABY 49 and 72 Chevy Trucks restored to original...close to it Drommer Stor....Norwegian for Dream Big http://s969.photobucket.com/albums/a...lle/?start=all https://www.flickr.com/photos/47922830@N03/ Pictures of my work and projects |
Cowboy Fan for Life!!!!!!
Re: Invisible weld seem video
Nice...........
1967 ShortBed Fleetside 3/4 Drop 350/700R4 Tilt wheel 18 x 8 Torque Thrust II's Future mods: All new gauges & wood bed My Zip is 23002 I ship UPS, USPS |
My welding supervisor office mate isn't impressed.
The inappropriate use of the cut off tool for grinding was not cool for a demo, and the welding wasn't the best.
'70gmc 3/4ton 4X4, re-arch and 2" add-a-leaf lift. '77 400sbc, '82 axles, d60front, 14bolt rear. Probably some 285/75/16 Toyo m/t's on my stock rims coming up. |
so show us a video of how it's "suppose to be done" then ...
Right in front of you.
Instead of all that grinding and filler rod.....with a panel as easy to access as that, why not hammer weld it with a torch, no filler rod or TIG needed.....
Pinstriping by Josh '78 Chevy Silverado SWB (lowered, 454) '90 Chevy Sport Truck '68 Dodge Charger R/T 1930 Ford Model A |
Today 01:33 PM The reason is because probably 90% of the restores out there use a mig welder. The process shows you HOW to get that smooth seem regardless of what method you use. No matter what welding method you use you NEED to remove the proud weld bead before you planish it. Pretty much all metal shapers Ive meet and talked too use a TIG because it creates less warpage. Martin, Whats your welding sup think of this one. http://fergusoncoachbuilding.blogspot.com/ He too uses the uncool use of a cutoff wheel for grinding as well as 100% of all body man Ive worked with. I guess we are all hacks
Currently working on How To Videos and custom metal 70 Chevelle gettin Sliced and Diced Anything But STOCK 70 Chevelle SS455 not a typo its a BUICK BABY 49 and 72 Chevy Trucks restored to original...close to it Drommer Stor....Norwegian for Dream Big http://s969.photobucket.com/albums/a...lle/?start=all https://www.flickr.com/photos/47922830@N03/ Pictures of my work and projects Last edited by sevt_chevelle; 05-03-2007 at 04:18 PM. |
#7 | |
![]() And I too use a cutoff wheel for grinding.....works very well in certain circumstances.....wear proper protection. ![]() Nothing wrong with the repair in the video......
Pinstriping by Josh '78 Chevy Silverado SWB (lowered, 454) '90 Chevy Sport Truck '68 Dodge Charger R/T 1930 Ford Model A Last edited by 69BBsuburban; 05-03-2007 at 05:48 PM. |
#8 | |
![]() Join Date: Jul 2005
![]() Quote:
The biggest problem people have, is other people Thou shalt be cool and not hassle ![]() Be a site supporter. ![]() The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 |
Here's the funny thing, I go thru about 100-200 4" cut off wheels a year and very rairly use one to cut something off
![]() They are the only thing I have found that get into 90* corners and are controlable. Kevin LFD Inc. |
cutoff wheels also produce less heat while grinding than grinding disks.
The Original HotRod KnifeMaker
![]() Join Date: Jan 2007
The fella in the vid went to a lot of work to share his technique with others. I like the repairs that require no bondo or skim coats, and all with common tools. I also use my cutoff tool for almost everything EXCEPT cuttin' stuff off.
Thanks for posting it. It wasn't as much fun as watching Jesse James make a gas tank with a BFR and his planishing wheel, but I have the tools for this ![]()
Dave 69 GMC SWB 2WD 454 Turbo 400 |
#12 | ||
#13 |
me being a metal worker i always enjoy seeing new techniecs
but also i could get the same effect by just using a metal buffing pad on a grinder, i know, ive seen me do it but even with that said i commend the guy for going through the trouble to show others howits done ![]()
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
#14 | |
#15 |
Maybe we should change the name to 4" grinding wheels, since everyone does it. My son gave me a wheel for my grinder, it has a bunch of stacked emery paper. Cleans up welds real nice and doesn't wear out...just a thought J.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
#16 |
someday it will be done!
yup the flap wheels are my tool of choice for finishing welds.they polish things up very nicely while not being over aggressive.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. ![]() ![]() ![]() '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
#17 |
Well, Whoop-dee-do!
![]() Join Date: Mar 2003
Using the edge of a cutoff wheel instead of the face of a grinding wheel makes a lot less heat & allows you to work the high spots with great control. But you must have great control to do it. Not everyone can get a feel for it. Just like porting cylinder heads. Either you pick up on the technique that works for you and learn rapidly how to hone your skills, or you don't learn and remain a butcher
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD ![]() '72 K20 500 Cad/TH400/NP205 SOLD ![]() '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car ![]() |
