Brake line questions
Ok so I am running new lines on my 72 C-30 dump truck. The PO has already ripped all the old lines out. rear lines are a no brainer, 1 line from the diff to the prop valve (power disk brakes on the front btw).
So question #1: I understand that the lines to both front calipers need to be equal length, so where was the original mounting of the lines, and is there supposed to be some kind of metering valve or will a standard T connector work just as well. #2 The master and prop vavle only had 1 line on it (other of course is MIA) It goes from the port on the rear of the master (for the fronts if I am right) to the front top port on the prop valve. Is that correct? I have done a search already and did not find what I thought might have been in the forums already. Thanks in advance.....oh and I got the camera back from my daughter, but now she cant find the stupid cable to hook it into the puter , so i cant post picks of my beast yet ![]() |
Post Whore
![]() Join Date: Feb 2000
Re: Brake line questions
Never heard anything about the front lines needing to be equal. Your dealing with hydraulic pressure that doesn't care if the line is 1 foot long or 10 feet long.
As for question #2, is it all drums or disks up front?
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Thanks, disks up front
Post Whore
Generally the rear line of the master is for the front brakes. Pop the top, whichever reservoir is larger goes to the front brakes. The prop valve should have one line going to the rear axle and then two lines to feed the front brakes.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 05-03-2007 at 11:21 AM. |
Thats what I thought, but this prop valve only has 1 for the front and 1 for the rear.
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
nope
![]() Join Date: Mar 2003
sounds like you have a drum brake prop valve
That would be just my luck.......but after looking at some pic's (mainly on ebay) of other trucks with the same setup.....most are 1/2 ton's they look the same.....but the plumbing from the m/c to the valve are all differant lol
member #16
![]() Join Date: Dec 1999
The 1/2 ton's lines run front to front- rear to rear. The 3/4 ton lines are opposite.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Ok does anyone know how they ran the line for the right side? I seen somwhere that it was run across the front of the crossmember but looking at the amount of crud on it, that doesn't apear to be right......
***Hijack Alert!!!***
Maybe this will help some others........... I'm working on a 1970 K20 (drums all around). I converted both front and rear to disks........theoretically, shouldn't I be able to re-use the booster, MC, and prop valve? I'm sure I'm missing something..... Thanks for any input!!! Misled |
#13 |
I took these pics a while back, a 71 C-30 I parted out. No longer have the frame or anything. Hope this is what you need.
LL= Large line: Rear brakes SL=Small line: Front discs |
#14 |
Awesome
#15 |
im in the process of doing the same thing.
Is there a cheaper way to go for the proportioning valve? I dont need a fancy on, just on that works.
72 GMC Camper Special 2500. currently has 350/350/14 bolt. 383 and 400 tranny is in the works. |
#16 | |
