Old 05-03-2007, 10:37 PM   #1
timzrides
timzrides's Avatar
Help, Point Me In The Right Direction
i just purchase a 47-53 cab and frame. the frame is a 48 with a 79 camaro front subframe but welded and boxed to the old 48. how can i get this thing LOW with regular suspension. if i go the bag route, do they sell something without going tubular. the rear end is an s10 posi with 3" blocks, any ideas or pictures.. thanks
timzrides is offline   Reply With Quote
Old 05-04-2007, 11:40 AM   #2
1-ton of fun
polishing a turd
1-ton of fun's Avatar
Re: Help, Point Me In The Right Direction
use drop springs for the front and rear if you don't want to use bags.
also there is a coil-over kit out now that bolts up to the stock 79 suspension that would allow you to set the height exactly where you wanted it
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
