05-03-2007, 11:56 PM | #1 |
Installing Power steering on 350
I have a 70 GMC 4x4 that I want to put Power Steering on. I have a Pump with Brackets and Steeering box. All the pulleys are single groove. Do I need just the Double Groove Balancer Pulley or will I need all new pulleys on th Alt., Water Pump etc.
Thanks for any help Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
05-04-2007, 12:15 AM | #2 |
Re: Installing Power steering on 350
i would recomend getting the double on the water pump also so that way if you run it all on one belt then you can put a second belt around just the crank and water pump for extra security so if the belt breaks you still have the water pump pushing the water
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
05-04-2007, 08:41 AM | #3 |
GreaseMonkey72 is right on. But to answer your question, no you don't have to get new pulleys.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! |
05-04-2007, 06:08 PM | #4 |
So Dual Pulley for the Damper and water pump? Thanks
Ron
05-04-2007, 08:50 PM | #5 |
My 69 4x4 has a single groove pully on the steering pump & water pump with a double groove on the crank and I have never had a problem but a double on the water pump would give me extra assurance as GreaseMonkey72 says.
Rob |
05-05-2007, 12:48 AM | #6 |
Hellasick
my 70 has a single on the crank, and a double on the waterpump.
still looking for a double crank pully, only thing i am missing for the power steering.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
05-05-2007, 01:02 AM | #7 |
here
