Old 05-04-2007, 11:36 AM   #1
76bonanza
76bonanza's Avatar
teflon tape question
My new fuel pressure guage say to use teflon tape. (I thought I could do with out and it leaks so they are smarter then me I guess)
Anyway I can never remember do you put it on to the right or left?
Also is there auto specific of can I use regular plumbers tape?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 05-04-2007, 11:47 AM   #2
bretcopsey
Re: teflon tape question
I always wrap clockwise, the same diretion the threads run. That way the loose end does not start unwrapping when you thread it together...
I know there is a special tape for natural gas, not sure if there is anything special for your application though.
My 51 project
http://www.cardomain.com/ride/2285825
My 68 Camaro project
http://www.cardomain.com/ride/2277404/1
bretcopsey is offline   Reply With Quote
Old 05-04-2007, 12:20 PM   #3
Psycho71
Psycho71's Avatar
Clockwise does keep it from unrolling as your threading. I always just use whatever's lying around. I wasn't aware that there's a special type for natural gas, learn something new every day.
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 05-04-2007, 12:48 PM   #4
shifty
Questionable
shifty's Avatar
and i use it on everything fuel and water related. don't discriminate.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 05-04-2007, 12:57 PM   #5
cdowns
cdowns's Avatar
i much prefer the teflon paste
Old 05-04-2007, 01:16 PM   #6
76bonanza
76bonanza's Avatar
I have never used the paste any reason you prefer it? Seems to me it would be more messy?
1968 c10
lowered 3" 4"
Old 05-04-2007, 01:27 PM   #7
JimKshortstep4x4
I am with cdowns as Teflon tape will shred and float down stream clogging up orfices. People have had really bad experiences with teflon tape in hydraulic systems as it will stop the valves from shifting.
Teflon paste or similar materials will stay in place when properly applied.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 05-04-2007, 01:31 PM   #8
cdowns
cdowns's Avatar
same reasons as jim listed
Old 05-04-2007, 02:07 PM   #9
76bonanza
76bonanza's Avatar
I see, well I have tape here so I think I will try it, I have no experince with the paste.
1968 c10
lowered 3" 4"
Old 05-04-2007, 02:45 PM   #10
grayw0lf
I like the teflon tape. Just apply it carefully & it isn't likely to end up clogging stuff up.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 05-04-2007, 04:05 PM   #11
neonlarry
neonlarry's Avatar
On any petro products you are supposed to the yellow tape.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 05-04-2007, 04:14 PM   #12
76bonanza
76bonanza's Avatar
The yellow tape is double thick and red or pink is triple thick. I know in some states yellow is required on natural gas lines. But never seen it prefered on anything else.
1968 c10
lowered 3" 4"
Old 05-04-2007, 04:29 PM   #13
Slammed70
Slammed70's Avatar
Ive never had luck with teflon on NPT fittings...maybe its just me and Im incompetent.
ultra rare corvette option package
Slammed70 is offline   Reply With Quote
Old 05-04-2007, 05:03 PM   #14
76bonanza
76bonanza's Avatar
So what did you use slammed? Nothing.
1968 c10
lowered 3" 4"
Old 05-04-2007, 05:14 PM   #15
Shane
Shane's Avatar
Teflon tape should not be relied upon for sealing purposes. It's proper use is to act as a lubricant when tightening the connections for the threads to fully engage.
Shane is offline   Reply With Quote
Old 05-04-2007, 05:17 PM   #16
Slammed70
Slammed70's Avatar
Indeed, nothing...never had a problem either. 'Cept on the fuel inlet fittings on Rochester carbs....they always strip out on me.
Old 05-04-2007, 05:41 PM   #17
76bonanza
76bonanza's Avatar
I never had a problem either untill this gauge. And then when I searched I found every site I looked at said all NPT fittings should be sealed with teflon. All major automotive companies say use teflon sealant of some kind on NPT fittings is a must. So then Im thinking hhmmm, anyway I am going to try it on this guage and see if it works. It is an aeroquip gauge and they say to use teflon tape with it.
1968 c10
lowered 3" 4"
Old 05-04-2007, 06:05 PM   #18
mbgmike
I agree on the paste. In chemical plants you won't hardly see tape used on any service except for the Instrument fitters on air lines. Actually most Piping Specs insist on Paste of some sort wether teflon,copper etc and say do not use tape. I have used paste for years
mbgmike is offline   Reply With Quote
Old 05-04-2007, 11:27 PM   #19
eedgell
It's the air up here
eedgell's Avatar
Guys, the only reason for the tape or the paste is lubrication period. Brass on brass or steel on brass, you need slick-um for the threads to tighten proper. So if it is a simple job and you have tape , perfect! If it is a liquid line than use paste because it stays in place. Either way just lube it!!!!
eedgell
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 05-05-2007, 11:21 AM   #20
mbgmike
Correct. It aids in assembly and helps prevent Galled Threads, corrosion and makes it easier to take apart. I can put paste on faster then tape is all.
eedgell
Old 05-05-2007, 06:16 PM   #21
byrd
Union Electrician
byrd's Avatar
most call the paste plumbers dope, nasty stuff, but works so much better than tape.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 05-05-2007, 06:40 PM   #22
76bonanza
76bonanza's Avatar
Any who, leak stopped, tape worked, how ever it works.
1968 c10
lowered 3" 4"
Old 05-05-2007, 08:31 PM   #23
Shane
Shane's Avatar
It worked because the tape lubricated the joint which allowed you to tightened the fitting further for a mechanical seal.
That's the entire purpose of a NPT type thread ... the further you turn, the tighter the connection. Thus the seal.
Old 05-05-2007, 08:56 PM   #24
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Working with hydraulics as much as I have been in the last couple of years, I've learned to like the pipe dope, hate the tape now, however, tape does come off of the fingers easier. We don't use tape on hydraulic machines because sometimes, you can get flakes off of the tape inside the fitting and it ends up sticking a valve.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
