Old 05-04-2007, 03:24 PM   #1
otsenre
otsenre's Avatar
cab removal
What do you guys think is easiest way to remove a cab off frame. I have been using camper jacks but is still a pain. I know I could make a A frame, but I would like something simple without bringing in all the neighbors to help. Thanks for any info and replies. Ernest
otsenre is offline   Reply With Quote
Old 05-04-2007, 03:54 PM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: cab removal
If you have a engine hoist some chain and a 4x4 it can be done rather easily
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 05-04-2007, 04:20 PM   #3
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Re: cab removal
Here's how I lift mine. Welded a bolt to the top of my engine hoist with the threads sticking up. Drilled a hole in the middle of a 4X4 to sit over the bolt (so it doesn't slide off). Stuck a 2X4 in the domelamp hole and out the windshield opening. Works perfect as long as the windshield and dome lamp are out. Other wise Rokcrln has some plans for a better unit if you plan to use it regularly.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 05-04-2007, 04:23 PM   #4
Stoney
Farm Truck
Stoney's Avatar
Re: cab removal
Use The Holes Were The Seat Belts Go With Chain And Pick It Up
1969 CST/10
1984 K5 Blazer 4x4
2016 Dodge Ram 2500 4x4
Mike
Jersey Village, Tx
Stoney is offline   Reply With Quote
Old 05-04-2007, 07:08 PM   #5
Bob D
Rolled on Paint Club
Bob D's Avatar
Re: cab removal
I used four 3/8" eyebolts in the holes where the cab was mounted, some chain and and an engine joist.
Bob
1970 GMC 1500 swb fleetside
SB 355ci.
Smog heads
Summit 1102 cam
Performer intake and carb.
Finally in about 1 piece in the yard.
Bob D is offline   Reply With Quote
Old 05-04-2007, 07:52 PM   #6
Blue85
Oilfield Trash
Blue85's Avatar
Re: cab removal
Good idea Bob D, does it lift off pretty even?
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 05-04-2007, 08:28 PM   #7
Rokcrln
Rokcrln's Avatar
Re: cab removal
Heres how I like to do it So easy even my wife can do it at about 5months along!! She rocks
Kevin
LFD inc.
See my sig!
Rokcrln is offline   Reply With Quote
Old 05-04-2007, 09:02 PM   #8
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Re: cab removal
I used my loader tractor....
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 05-04-2007, 09:32 PM   #9
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: cab removal
Rokcrln - i bet she loves the fact that you circled it so its easier to see
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 05-04-2007, 09:35 PM   #10
shifty
Questionable
shifty's Avatar
Re: cab removal
i used a cherrypicker also.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 05-04-2007, 09:42 PM   #11
otsenre
otsenre's Avatar
Re: cab removal
Thanks for the ideas guys, I will give it a shot tommorrow! Ernest
Old 05-07-2007, 11:03 PM   #12
alschevy
Re: cab removal
one of my friends used a hug tree a comealong and some chains
alschevy is offline   Reply With Quote
Old 05-08-2007, 01:12 PM   #13
otsenre
otsenre's Avatar
Re: cab removal
I made a trailer out of longbed frame I had. When I cut front frame section off, I drilled holes to match my seat mounting holes. I bolted them on so they stuck out about a foot on each side. Then I used my camper jacks and lifted it straight up. I will post pics when I drop the oter one back on. Worked like a charm!
Old 05-08-2007, 02:20 PM   #14
mvfd70
mvfd70's Avatar
Re: cab removal
I used a floor jack and 4 jack stands. Took me a while cuz i didn't want to tilt the cab too far to one side. I set the frame on some home made dollies I made and rolled it under the cab. Then I jacked the frame up to the cab, bolted it on, did a little more jacking and moved the jack stands from under the cab to under the frame rails. I was gonna take pics of this but my digital camera decided it was tired of working. One thing about this though, I wouldn't recommend this unless you plan on replacing the outer rockers. There are some nice little dents from the jack stands now. I needed to replace them anyway and I figured that would happen so it didnt really matter to me.
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 05-08-2007, 02:24 PM   #15
mvfd70
mvfd70's Avatar
Re: cab removal
One more quick word of advice. DON'T wrap a strap through the doors and over the room then use a hoist to lift it from the strap. The guy I bought it off of did this. He had it in the air when i showed up to load it. It almost fell over too since he didnt extend the legs on his cherry picker. Now I have to straighted the drip rails. I'm just glad he didn't crack the windshield.
Old 05-08-2007, 02:25 PM   #16
Chris H
72 C30 Trailer Queen
Chris H's Avatar
Re: cab removal
My favorite method, cab and front clip in one piece.
Chris H
72 C30 133"
72 C30 157" flat-dump
69 C10 short fleet
71 ElCamino
2000 K2500 crewcab shortbed (sold, sorry old friend)
2005 GMC 2500HD shortcrew Duramax
2006 K1500 RCSB
and a couple other projects/parts
Chris H is offline   Reply With Quote
Old 05-08-2007, 03:03 PM   #17
Bad4wd
Re: cab removal
I bought a HF 110 v 880 lbs winch & mounted it on some 4x6 8'-beams in the attic of the garage. Then I made some mounts that bolt into the factory hood hinges to hook my straps to. It's stationary but works & when i'm done with it I just motor it up into the attic,close the trap door & out of the way.
Dave.
[IMG][/IMG]
[IMG][/IMG]
Bad4wd is offline   Reply With Quote
