05-04-2007, 05:53 PM | #1 |
Designated A-hole!
2/4 drop?
What's a cheap way to do this? Thinking of doing it on my truck. I've got a spare set of springs on a parts truck if cutting/heating is what I go with and I don't like it. What's the best source for lowering springs? Just bouncing ideas around in my empty head.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
05-04-2007, 06:38 PM | #2 |
Re: 2/4 drop?
Ece
Alex 1971 Lil' Red 350 SBC 700R4 |
05-04-2007, 07:02 PM | #3 |
67-72 Addict!
Re: 2/4 drop?
Krue- the cheapest way is to cut a coil out of your spare springs (FREE) and buy a set of rear drop springs at GMCPauls for $95(Cheap) You will not need to buy lowering shocks with this mild of a drop. Captain Keneival has my old cut springs on his truck now and they look great!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 05-04-2007 at 07:03 PM. |
05-04-2007, 07:29 PM | #4 | |
Re: 2/4 drop?
1970 C10 |
05-04-2007, 07:35 PM | #5 |
LS1 Lover
Re: 2/4 drop?
How low of a drop can you accomplish up front with cutting springs? I have all the parts for my 6'' drop in the rear but the front requires alot more.
USMC |
05-04-2007, 07:49 PM | #6 |
Re: 2/4 drop?
I'm also trying to keep my project low buck, I'm going to cut one coil off the front which should give around 2" drop. On the rear I'm going to try a 3" square tube drop like the one pictured here that Iveldesigns posted a while back.
I was going to start this weekend on this, but the GMC decided to blow a head gasket this week, so my priorities have changed. I'll post pics when I get it done.
68 GMC 64 1/2 Mustang convert A bachelor's life is no life for a single man." - Samuel Goldwyn |
05-04-2007, 08:12 PM | #7 |
67-72 Addict!
Re: 2/4 drop?
On Captain Knievals truck springs, I cut 1.25 coils out of each spring and got a hair less than 3" drop as you see in his pics. I wouldn't cut anymore than that.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
05-04-2007, 08:27 PM | #8 |
Re: 2/4 drop?
Cut Springs?? How you going to get in and out of your driveway??
05-04-2007, 08:42 PM | #9 |
LS1 Lover
Re: 2/4 drop?
Thanks I am going to give it a shot tomorrow.
USMC |
05-05-2007, 07:14 AM | #10 | |
Chevy Guy
Re: 2/4 drop?
In another post discussing cutting front coils, there was mention of the front coils 'popping' when turning. What should be done to avoid that? Thanks. Last edited by 57T210; 05-05-2007 at 07:15 AM. |
05-05-2007, 02:05 PM | #11 |
Designated A-hole!
Re: 2/4 drop?
I thought you were only supposed to cut the springs an even amount of coils due to the way they fit in the cups.?
05-05-2007, 02:49 PM | #12 |
Gone Fishing
Re: 2/4 drop?
You can cut 1 ring out of the front coil and find some old big car springs to lower the rear. They won't take much of a load weight wise but they ride good and lower it to about what your looking for. I might even still have some
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
05-05-2007, 03:53 PM | #13 |
Re: 2/4 drop?
Krue, heres the cheapest way. Cut one coil from the front springs & find a buddy that has an old set of chevelle, elcamino, cutlass style rear springs for the back. Free...
05-05-2007, 04:10 PM | #14 |
Designated A-hole!
Re: 2/4 drop?
I still plan on using my truck like a truck, so I've got to be able to carry a load. May just leave it stock height.
05-05-2007, 05:26 PM | #15 |
Gone Fishing
Re: 2/4 drop?
Well I still used mine as a truck some and it could get a little scary with a load in ruff road conditions. If your still gonna use it as a truck, my opinion is to either lower it the right way with the coponents from ECE or leave it stock. Just my .02
05-05-2007, 05:49 PM | #16 |
1969 Short, Fleet, and Beat
Re: 2/4 drop?
If, you plan on using you truck to tow and haul. Then, cheap should not be put into the equation. I am on the same boat and I plan on going 2" spindles in the front and a good set of 4" dropped coils from the rear. I am really thinking of Early Classics Enterprises for my parts.
05-05-2007, 05:57 PM | #17 |
Designated A-hole!
Re: 2/4 drop?
Forget it then, what's the point in having a truck I can't use as a truck.
05-05-2007, 06:00 PM | #18 |
Re: 2/4 drop?
use the 3/4 ton as a truck and lower the gmc
05-05-2007, 06:02 PM | #19 |
Designated A-hole!
Re: 2/4 drop?
Still don't have a title for the 3/4t.
05-05-2007, 06:36 PM | #20 |
Re: 2/4 drop?
Do it right... I accomplished my stance with 2.5" drop spindles and 4" drop coils in the rear. I'm really happy with the ride and stance, also you don't have to worry about any rubbing! My truck handles great and I regularly haul motorcycles, engines, snomobiles...etc. It does get a little squirly goin down the freeway with a bunch of weight in the rear... but that's only above 85 or so here's some pics of the stance.
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project. 1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver. |
05-05-2007, 10:22 PM | #21 |
Designated A-hole!
Re: 2/4 drop?
I'll put it on the list of "When I have some money".
05-05-2007, 10:34 PM | #22 |
Re: 2/4 drop?
with four inch coils in the back you would still be able to haul plenty... maybe not like a huge load...
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4 70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s |
05-05-2007, 11:32 PM | #23 |
laying low
Re: 2/4 drop?
Krue I know you said "cheap" but what about cutting a front coil, using passenger car rears and add a helper bag or air shock for a little assistance when hauling? Shouldn't cost all that much.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
05-06-2007, 12:59 AM | #24 |
Re: 2/4 drop?
krue you can do what i did. i put taller tires on to fill my wheel wells. gives the illusion of being lower increases load capasity, and gives you a higher final drive ratio you win all the way around
common sense isn't so common anymore |
05-06-2007, 07:20 AM | #25 |
Chevy Guy
Re: 2/4 drop?
Wreckless,
That's a good looking truck. Just checked out the ECE 2/4 lowering kit. Seems reasonable. Anything else one should figure on doing while they're installing the kit? For example, with a 2/4 drop, you wouldn't need the C notch, would you? Regards. Last edited by 57T210; 05-06-2007 at 07:29 AM. |
