HEI or Mallory HyFire?
I'm in the middle of swapping the 350 out of my 71 K20. It was already running HEI, so keeping that setup seems like it would be easiest.
The motor that's going in already has some kind of *bling* Mallory dizzy, Promaster coil, and a separate box that controls variable advance curves or something like that? This is also a 350, but with a decked block and lots of $$ into port-matching and head polishing and balancing and whatnot. My inclination is to keep it simple with the HEI if the power difference is negligible, but I don't want to waste potential by going cheap... I like the fact that it would still run off-the-shelf parts as well. Which would you run and why? |
Re: HEI or Mallory HyFire?
I have used both the Mallory Unilite/Hyfire, and the HEI setups. I really couldn't tell any difference. In the future, I will probably just use the HEI. For simplicity, parts availability, and price, they're hard to beat.
"Negative people always seem to have a problem for every solution" |
#3 | |
Thanks. I think I just needed a voice with experience to confirm what I already suspected. I'm not going to be racing it, so programming advance curves just doesn't sound necessary. |
