Old 05-04-2007, 09:03 PM   #1
hewlett2002000
hewlett2002000's Avatar
axle swap????
could i take the axles from my 84 lwb fit on my 66 lwb fleet? i want to do that so ill have the 5-lug in back too. right now its 5 in front and 6 in back.
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 05-04-2007, 09:04 PM   #2
1969k10stepside
Re: axle swap????
Would have to convert it for coil springs....And a panhard bar..to use whole axle
If you mean just swapping the axles,the axles alone just wont slide into your housing,they are longer on a 5 lug
1969k10stepside is offline   Reply With Quote
Old 05-05-2007, 06:01 PM   #3
psychorodder
psychorodder's Avatar
Re: axle swap????
Put a 71 72 rear end in, is 5 lug and 3/4 inch longer on each side
psychorodder is offline   Reply With Quote
