Old 05-05-2007, 03:43 PM   #1
69 air cab
opps.....oh no
I was working on my 71 today which was my uncles truck that satup 14 years. I had changed the oil and pulled the distributor. I put a oil pump primer in and rotated. When I pulled it out the oil pump shaft cam with it. Is there a way to get that shaft back in or am I about to start dissasmbly of that engine?
It's a 350
Help?????
69 air cab is offline   Reply With Quote
Old 05-05-2007, 04:17 PM   #2
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: opps.....oh no
Just slide it back down there. No big deal really. The little plastic thingy that held it there probably cracked years ago. The distributor will hold it in fine.
hgs_notes is offline   Reply With Quote
Old 05-05-2007, 04:20 PM   #3
shaneschevys
Its always something!
shaneschevys's Avatar
Re: opps.....oh no
I would replace the plastic piece also. Shouldnt be all that big of a deal to do.
79 p10 stepvan
72 Short Fleetside
72 Suburban
67 GMC One Ton Flatbed
64 Short Fleetside
57 Chevy 2DR Hard Top
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Member of the patina club
shaneschevys is offline   Reply With Quote
Old 05-05-2007, 04:35 PM   #4
krue
Designated A-hole!
krue's Avatar
Re: opps.....oh no
You can do it from the top, I replace the plastic thingy on mine with the dizzy out and the intake off with a pair of needlenose pliers. With the intake on I would use the LOOOOONNNNG needlenose pliers I see sometimes.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 05-05-2007, 05:33 PM   #5
eedgell
It's the air up here
eedgell's Avatar
Re: opps.....oh no
with every thing so far. When I rebuild, or replace, I usually use a TRW high volume pump that comes with a sleel collar instead of the plastic one. You can probably buy a new shaft with the steel collar with out the pump. Any way it is a much better idea than stock. By the way the steel collar is pinned to the shaft.
eedgell
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 05-05-2007, 07:08 PM   #6
69 air cab
Re: opps.....oh no
thanks guys.........I followed your advice and got it back in.
thanks again.
