Old 05-05-2007, 05:38 PM   #1
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
TH400 kickdown wiring question
The kickdown on Dad's 72 doesn't work. It has the switch on the gas pedal; the pink runs to the fuse block, and the yelloe rund through the firewall. Under the hood, the yellow wire ends about 10"-12" from the firewall with a factory spade connector on it. Nothing that I can see that it should plug into.
Down on the tranny, there is a sensor or ?? right near the shift linkage with nothing attached to it. I think it had two terminals on it.
My wiring diagram doesn't show any wiring for a TH 400. Can anyone tell me how this needs to be wired?
Thanks!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 05-05-2007, 06:33 PM   #2
gator2511
gator2511's Avatar
Re: TH400 kickdown wiring question
My TH400 has a hot wire going to the kickdown switch. When the switch is activated the switch makes contact and sends 12 volts down to the tranny solenoid. The solenoid is located on the driver side of the tranny near the gear selector linkage. You found it, its just not a sensor. The hot wire plugs onto the terminal on the solenoid and kicks the tranny down into passing gear. It goes to ground to complete the circuit through the transmission case. It should have only one terminal on it.
gator2511 is offline   Reply With Quote
Old 05-05-2007, 06:57 PM   #3
JimKshortstep4x4
The 72 was probably set up with the TCS system and the extra spade would be for the signal to the TCS that the tranny was in high gear. The terminals
look like a "T" when looking at the detent switch, (one spade is vertical and the other is horozontal). The vertical spade is the detent switch connection.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 05-05-2007, 07:10 PM   #4
gator2511
gator2511's Avatar
Jim
Thanks for helping keep me straight!
Old 05-05-2007, 07:16 PM   #5
JimKshortstep4x4
gator2511,
It is easy to forget about the TCS setup on these trucks as most have long been removed!
Jim
Old 05-05-2007, 07:29 PM   #6
glock35ipsc
Thanks guys! We'll get it hooked back up tomorrow then.
Bob
