Rally wheels, What tire size?
Hey I just got a set of 15x8 rallies for the truck and now I need some tires. I looked around here a bit and read a few other posts.
I need the tires to tuck if and when I bag it. For now they just have to fit with the 4/6 drop that is coming soon. I looked at John's beautiful blue truck with blue rallies and I like them. I believe his sizes are 265/50. I want some meat but I don't want it to rub and I want to run the same size front and back. What sizes does everybody run?
1970 Chevy C10 "Under Construction" ![]() 2002 Chevy S10 V6 ![]() |
i love summertime
Re: Rally wheels, What tire size?
im running 275s all the way around, they would tuck with bags, 295s i dont believe would, not with the ralley offset anyways
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
275's here too (before and after white lettering -- boo ya!)
1970 C10 ![]() |
LS1 Lover
275/60/15 I have them on all four.
USMC ![]() |
OK, 275/60 anybody have them with bags?
Anybody????
i love summertime
ttt for ya, im also wondering this too
Ok one more time. Cap want size drop do you have on your truck?
Not sure about bags, but I know seeten's truck had 275/60's with about a 4/6 drop with no rubbing issues. I would probably lean more to a 245/60 or 255/60 tire for the front and run the 275/60's in the rear. What kind of rallies do you have? Vette rallies? Cheyenne rallies? 6 lug or 5 lug? What depth backspacing?
I would almost recommend 7" rallies for the front if you plan to bag it.
I have the 5 lug rallies 8 inch. I really would like to run all tires the same size is the reason I got all 8 inch.
I had 275/70 r-15's on my bagged truck, but I also had uncut lower cups. I didn't have any clearance issues and might have been able to go 2" lower in the front.
I would think 60's would not be an issue.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
295/50/15's on the rear, they stick out the wheel well about 1" with 15x8's. When I measured them, they look more like 8.5's???? 295/50's are out of the game for ya. 60's are about as wide as you can go.
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
#13 |
It's just a 3/4. No bags.
1970 C10 ![]() |
#14 |
Aight so 275/60 it is. Now to find out the cost on some BFg's in that size. Thanks for all the help guys.
#15 |
some people dont realize that the first # is your width example 275 is 275 mm across. 60 is 60% of 275mm, and is your height. so just for example and 275 50 would be the same width as a 275 60 but slightly smaller diameter. hope this helps
#16 |
blood type; Retumbo
#17 |
also check www.tirerack.com
I've had good experiences with them, they have a nice selection, great rating system, and usually you can find something on sale cheap... Hell, even if i'm not gonna buy from them, I do my research there. ![]()
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
#18 |
![]() Join Date: Sep 2006
I've had the same question but hadn't asked it yet because I wasn't quite ready to buy tires.
However, I've got 10 inch rallyes. Will I have any problems when I bag my truck?
BRENT ![]() -'68 Stepside Project -'98 Z71 Daily Driver -Enough extra parts to build another truck and a half |
#19 |
![]() Join Date: Nov 2001
math for 275/60-15...
275 x .60( 60% of 275 is sidewall height) = 165 (per sidewall), 165 x 2 (2 sidewalls) = 330, 330 divided by 25.4 = 12.99 (converted to inches), 12.99 + 15 (rim diameter) = 27.99 inch tall tire... this works with any rim diameter...
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 05-08-2007 at 12:22 PM. |
#20 |
Just got a set of 275/60R15 BFG for $96 each with free shipping. Bought 255/60R15 for the fronts for $86 each. Got em all from http://www.discounttiredirect.com. The 255's were on back order for a week but all arrived quickly after they came in.
71 Cheyenne SWB |
#21 |
What size would you guys recommend for the narrower 7" that some run on the front?
Thanks. |
#22 |
I Have A 2 1/2 Inch And 5 Inch Drop. I To Have Rallies And Am Running 255/70 Tires
![]() It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan |
#23 |
![]() Join Date: Sep 2005
i have 255/70r15 on a set of 15x10 chrome rallys
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
#24 |
Shane, I'm running 245/60's on my van rallys, looks great. I know 72MARIO is running 255/60's on his.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
#25 |
I am runnig 275/60/15's on 8" truck rallye wheels. I have a ece 4/6 drop. no rubbing issues. If you bagged it the fronts would probally rub because the offset is out to far and would rub the fender opening. Hope this helps.
