05-05-2007, 07:39 PM | #1 |
The Original HotRod KnifeMaker
Will this 5 speed hold up to 396?
Or is this a lighter tranny than they use with big V8's?
Thanks,
Dave 69 GMC SWB 2WD 454 Turbo 400 |
05-05-2007, 08:46 PM | #2 |
Re: Will this 5 speed hold up to 396?
Which one??
05-06-2007, 04:48 AM | #3 |
Jeeez, sorry.
There was ad ad on craigs list for a s10 blazer with a small engine and manual 5 speed..... too light for a 396?
05-06-2007, 04:54 AM | #4 |
its possible that it is, but if you give the make of it someone can say for sure
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
05-06-2007, 08:30 AM | #5 |
5 speed from S10 and Big block.... Disaster waiting to happen. The S10 tranny didn't take much from a built small block. If you want one I would look at ones from a 88 and up that came behind a V8 (NV3500 I believe is the tranny)
05-06-2007, 10:40 AM | #6 |
The NV 3500 also came behind 4.3 s-10 trucks as well as the full size trucks.
The tranny is the same regardless of big or small truck, shifter placement is the difference. I would not put this tranny behind a big block- too much torque.
ongoing 1970 c 10 lwb 1994 z-28 few mods.-owned since new 1978 vette silver/grey 25th anniv. paint Last edited by chevybill; 05-06-2007 at 10:40 AM. |
05-06-2007, 11:04 AM | #7 |
blood type; Retumbo
they didnt even hold well behind a 4 cyl. I wouldnt expect it to last long behind a BB
05-06-2007, 01:48 PM | #8 |
Most 28.V6 and 4 banger S10s came with the T5 tranny. Very weak. It even cam in some v8 cars, but didn't take much abuse. The NV3500 was the 1/2 ton 4.3 (S10 or fullsize) and some small block trannys. It does OK for general use behind a non-built V8 small block. The one I am thinking about came in the 3/4 ton& 4x4 V8 models normally (NV4500 I think). It will take more abuse and might work behind the big block just fine.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 05-06-2007 at 01:52 PM. |
05-06-2007, 02:17 PM | #9 |
If you want the manual tranny, overdrive and a big Block (all in the same vehicle), you'll probably have to upgrade to a Tremec 5 or 6 speed or similar setup to make the "fear factor" go away.
If memory serves, plan on contributing about $2.5K to the cause. For that amount or less, you could probably go with a beefed up TH700 and sleep better every night.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
05-06-2007, 06:54 PM | #10 | |
05-08-2007, 09:35 PM | #11 |
I was pretty sure of the answer when I asked. Thanks to all for the input.
