Old 05-06-2007, 05:10 AM   #1
rcbildr
rcbildr's Avatar
My latest project...84 Burb engine swap
Just thought I would share my lastest project that I am almost finished with.
I picked up this 84 3/4ton Suburban with a 454/TH-400, and the 1-ton rear end for free. The catch was the engine had a knock, or so I was told, and the interior needed a major clean up. After hearing it run, my friend and I think it is valve train related. I wanted the engine from it and my Brother said he was interested in the rest of it. I had a good 350 (from my 71 chevy truck) sitting in my shop, so we decided to put the 350 in place of the 454.
I acquired the manifolds and accessory brackets and pulleys to convert the 350 over to a long water pump set up and have been slowly getting it set up in the Burb...I was delayed a week or so because I was sick. In addition to the manifolds and accessory brackets and pulleys, I had to replace the radiator (the original came out in 2 pieces), find a different fan shroud, rebuild the alternator, and I've installed an extra oil pressure and water temperature gage.
Late Saturday evening I have pretty much finished the engine swap and got it running nicely...will try to have pics later on today. Eventually, we are going to look for the parts to put cruise control back on and reinstall the A/C. All that's left to make it a driver is to bleed the rear brakes and replace the window in the tailgate..the original was broken. After the test drive my Brother gets to deal with the interior.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
