Old 05-06-2007, 07:54 AM   #1
Shamil
Shamil's Avatar
I need someone help
I found on Summit web site an adapter that convert from 1bbl to 2bbl for a certain type of carburetor, the guy there told me that what installed on my engine inline 292; the monoject is bigger than what should be installed on the adapter… I thank him for his support….
Can someone explain to me working mechanism of the carb and manifold, if I manage to customize an adapter that fit on a 4bbl carb on a stock 1bbl manifold would the carb. 4bbl Work?
Shamil is offline   Reply With Quote
Old 05-06-2007, 09:57 AM   #2
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: I need someone help
I will take a stab here.
The proper way to install a 2/4 barrel carb. in place of a signal barrel is buy the complete intake assembly. These intakes have larger Pentiums and runners to allow the extra air/fuel to mix better before entering the cylinder. Also unless your engine is built pretty good I would suggest leaving the 4 bbl on the shelf.
Then move to the ignition system and up-date to a high output performance coil and wires etc. Then to the exhaust system. A signal header would be better than the stock manifold but split headers would be even better for getting the extra flow out of the engine.
When I was a youngster I installed a 4 bbl adapter/carb. to my 2 bbl intake, Yeah it did run but not much of a performance gain and sucked the gas and didn't stay on there long.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 05-07-2007, 11:46 AM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
It sounds like you would be creating a huge mess for yourself. Can your engine benefit from a 4bbl carb? Even if it can, I doubt the intake is up to it. I admit, I'm speculating here. These comments are not based on any experience with the setup.
You might check with Clifford Performance. They are the folks that specialize in six cylinder performance parts.
http://www.cliffordperformance.net/M...gory_Code=C250
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 05-07-2007, 03:45 PM   #4
Mr79C10
It Is What It Is,,,,
Mr79C10's Avatar
My 79 has a L6 in it. Would love to put on a header and differ. intake but I have that head that has the header and intake combined.
*79 C10 Short Box ST8 6 bang'r *
*Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT
*__--__*
79 C-10 project
.........................__
..............._____ l __\___
..............|_(O)_ |___(O) ]
FAQ INDEX Thread
The Kulture
My Rat Den
Mr79C10 is offline   Reply With Quote
Old 05-07-2007, 04:10 PM   #5
knightlife
Dark Heart Motorsports
knightlife's Avatar
or you could always slap a 4 barrel on it they have an intake in the LMC catalogs...just a lil FYI fer ye...dunno if you wanna put 600 cfm's to it tho *shrugs*
How Deep Can YOU Bleed..?
1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter
2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD!
knightlife is offline   Reply With Quote
