Hollister, CA.
![]() Join Date: Sep 2006
Timing should be set at........?
Hello there guys. I'm usually at the 60-66, but I have a question.
My cousing drove down from Nevada City with his 69 C-10 with a 307 with 2BRL I installed a NEW HEI to replace his points dist. What should the timing be at ? 10-12 BTC or what ? My Craftman timing gun that I've had since I was 14 (35 now) finally broke...so I'm going shopping today. The truck is running, but a little too advanced (pinging) Thanks for your help John
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
Re: Timing should be set at........?
i am thinking off my head 8-12
![]() if you have a aftermarket cam thats out the window ![]() |
Hollister, CA.
OK...thanks.
Now while were at it How about a 350..202's...600 CFM....Comp 480/280 cam What would you recommend that timing be at ?? ![]() - ![]() Thanks John
Hollister, CA.
Ttt
It's the air up here
I am not sure of your altitude, but here at 6000ft I set mine with after market cams as far advanced as I can, till they ping then back them off a bit. Some engines I have built here run 40-50 deg. advanced. My rule of thumb with after market cam is as far advanced as you can go. It may be different where you are though. Up here throw out the timing light and do it by ear and feel. Where it runs the best.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c ![]() Never drink down stream of the herd! Eric |
as stated before ussually you advance the timing until you get spark knock or it kicks back on the starter, then back off a few degrees
,Clint LOUD PIPES SAVE LIVES ![]() 69 C-10 short stepside 406 sbc, 02 YAMAHA WR250F, 07 SUZUKI SV650S, 81 Grand Prix 355 sbc, 81 XT 500 YAMAHA |
