Old 05-06-2007, 04:23 PM   #1
cstm68
cstm68's Avatar
hows my rust ??
ok so i just pulled my windsheild and found that my rust isn as bat as i though it would be !
but it is there, from thease pics how do you guys think i shopuld handle this.
a) cut it all out and replace.
b) wire wheel and use some all metal or por 15 on it
c) ... you tell me
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 05-06-2007, 04:29 PM   #2
dan42
dan42's Avatar
Re: hows my rust ??
Might want to post that on the '60-'66 message board.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 05-06-2007, 04:32 PM   #3
heavy71chevy
heavy71chevy's Avatar
Re: hows my rust ??
wire brush it clean and lightly sand it..weld up anyholes and patch with hammered sheetmetal weld up all holes found and prime wit high build and work from there
"Dixie Destroyer"
71 C10 LWB Fleet
Future Blown Prostreet Monster
heavy71chevy is offline   Reply With Quote
Old 05-06-2007, 04:38 PM   #4
cstm68
cstm68's Avatar
Re: hows my rust ??
why ?? its a 68
Old 05-06-2007, 05:24 PM   #5
65-72 chevytoys
65-72 chevytoys's Avatar
Re: hows my rust ??
doesnt look that bad wire wheel, epoxy seal it and weld any pinholes, do any body work needed then prime and paint.
2004 Chevy Silverado 1500LS SWB 5.3L
2004 Corvette Z16 #770
Wish I had not sold 72 blazer
65-72 chevytoys is offline   Reply With Quote
Old 05-06-2007, 05:33 PM   #6
cstm68
cstm68's Avatar
Re: hows my rust ??
thanx guys
Old 05-06-2007, 06:18 PM   #7
Rokcrln
Rokcrln's Avatar
Re: hows my rust ??
Yes yours is not bad at all. Wire wheel it all up and then pour some rust treatment in the visor holes and let it soak and seap thru any holes in the pinch welt of the front window. Then epoxy prime any exposed metal and get on your way.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 05-06-2007, 07:24 PM   #8
kyull67
kyull67's Avatar
Re: hows my rust ??
kyull67 is offline   Reply With Quote
Old 05-06-2007, 07:28 PM   #9
bodyman9174
Re: hows my rust ??
Wish mine was that clean
Cars i have done
bodyman9174 is offline   Reply With Quote
Old 05-07-2007, 12:41 AM   #10
Aarons72s
Re: hows my rust ??
That rust aint to bad. If you got a spot sand blaster, try that. Especially where the seams are at all four corners. Other than that I agree with the above.
Aarons72s is offline   Reply With Quote
Old 05-07-2007, 12:51 AM   #11
cstm68
cstm68's Avatar
Re: hows my rust ??
ok so i hit it all with the wire wheel and got most of the rust off.
i do have a spot sandblaster and i will be using that in the corners and the 4 seams tomarow.
