Who said you can't do this?
Who said you can't pull a motor out with the hood still on? On my way to the 383 build. Thanks for helping out 70c10.......
1997 GMC Sierra Ext 1965 Mustang Last edited by 70GMCer; 05-06-2007 at 05:02 PM. |
Re: Who said you can't do this?
Cool, what are the plans for it.
You tha man. Not only did he pull the engine with the hood on. He did it with the upper radiator hose on as well. ![]()
2004 Chevy Silverado 1500LS SWB 5.3L 2004 Corvette Z16 #770 Wish I had not sold 72 blazer Last edited by 65-72 chevytoys; 05-06-2007 at 05:28 PM. |
![]() Join Date: Sep 2005
not something i cma going to try i going pull my hood be a good time to clean out heater box
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
383 time for this 4 bolt block. Going to the machine shop tomorrow..
1997 GMC Sierra Ext 1965 Mustang |
Why not just take off the hood? Let's a lot more light shine in on the subject....
#6 | |
67-72 Addict!
![]() Jim_PA, Steve's truck has near perfect panel alignment and it was easier to just to pull the motor carefully instead of the aggravation later of realigning everything. ![]() One other thing 70GMCer didn't mention was the motor was pulled and disassembled to a bare block in about 5 hours or so. ![]()
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
sufficiently talented fool
![]() Join Date: Jun 2006
you guys are fast!! You ready to big block my truck????? lol
"it's impossible to be surrounded by idiots when you are part of the circle" ![]() 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
Cowboy Fan for Life!!!!!!
Here's a little trick to help with panel re-alignment. Presuming that you have excellent hood gaps and don't want to "mess them up", without loosening any bolts anywhere, take an 1/8" drill bit and drill 1 small hole through your hinge and through the metal where it bolts up to the hood. One hole on each hinge. Then just take the hood off. Once you are ready to re-install the hood, just get the hood on close and then take an 1/8" pop rivet or drill bit or whatever and get both holes re-aligned, then simply tighten down all you bolts. You automatically have the exact same gaps as before. Hope this helps.......................Bamm!
1967 ShortBed Fleetside 3/4 Drop 350/700R4 Tilt wheel 18 x 8 Torque Thrust II's Future mods: All new gauges & wood bed My Zip is 23002 I ship UPS, USPS |
67-72 Addict!
![]() ![]() ![]() I can't believe Steve didn't post a pic of the bare block after we put it in the back of his work van ![]() Jerry, that's a great tip. We were discussing this tip a few weeks ago in 70GMCers garage!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 05-06-2007 at 10:36 PM. |
GEARHEAD
Nice! Just did that with the tow truck at the shop where we picked up a parts truck the other week.
He wanted the engine and gave me the rest. About 25 min. and the truck was rolling down the road minus one engine. |
i just pulled and reinstalled mine with out removing the hood this weekend too. the engine is easy alone the hood is not
common sense isn't so common anymore |
#13 |
and, I just wanted to see if I could do it without removing the hood.......
