battery cables smoking.........???
I have an old 71, 350 that was sitting for 14 years. In trying to crank it (engine does turn over) the battery cables get hot and start smoking in just a short time.
What could this be? |
Re: battery cables smoking.........???
Bad ground?
-Chris
![]() Join Date: Sep 2002
I would agree with that, its most likely a bad ground. The wires are probably crossed or one of the wires is stripped and grounding out. Hope you get it figured out.
Chris
1970 Chevy C-10 P/U, Shortbed, Fleetside - 5/7 drop, 496, TH400, 12 bolt. BUILD THREAD - http://67-72chevytrucks.com/vboard/s...d.php?t=404481 2012 F250 Super Duty P/U - intake, exhaust, tuner, 4" lift with 35's 2017 Chevy Suburban (Wifes Car) - Fully Loaded & Stock "Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem." Ronald Reagan, President of the United States; 1985 |
sufficiently talented fool
![]() Join Date: Jun 2006
It is either the starter drawing too many amps, or a bad ground. Clean the connections at the block end of the ground cable, both ends at the battery. Check and make sure the starter bols are tight. See what happens then.
"it's impossible to be surrounded by idiots when you are part of the circle" ![]() 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
THanks guys. I kind of felt it was started related so I will check both
