Old 05-06-2007, 11:17 PM   #1
Moneypit
Three little letters are making me fell dumb...PCV
I know all about what a PCV system is for and for the most part how it works, and until today I thought I knew how one was supposed to be hooked up. What has me stumped is when looking through the installation manual for my Edelbrock 1406 carb it shows the 3/8 inlet on the front of the carb as being for the PCV. I have never came across a PCV system that was hooked through the carb. All I've ever seen was a PCV valve on top of the valve cover and connected to the bottom side of the air cleaner. So can anyone tell me what the inlet on the front of the carb is for and how it is supposed to be hooked up.
In case anyone is wondering here is a link that shows the inlet on the carb (you have to scroll down a bit):
http://www.edelbrock.com/automotive_.../1000/1406.pdf
1968 Chevy C10
1967 Mustang
1976 Honda XL350
2006 Victory Vegas 8-Ball
2012 Ram 1500 4x4
Moneypit is offline   Reply With Quote
Old 05-06-2007, 11:25 PM   #2
Ilike 72"s
Re: Three little letters are making me fell dumb...PCV
Mine is on the back of the carb, but its a holley. All the PVC needs is a vacume port to pull the crankcase excess pressure and or smoke out of the block.
Ilike 72"s is offline   Reply With Quote
Old 05-06-2007, 11:27 PM   #3
woodridge
woodridge's Avatar
The pipe that hooks to the air cleaner is for the fresh air drawn into the crankcase. The PCV valve has to be connected to a vacume source i.e. bottom of carb to work.
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline   Reply With Quote
Old 05-07-2007, 02:19 AM   #4
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
This picture show's my PVC connected to a carb adaptor plate using a port on the adaptor plate as a vacuum source. There are area's as well at the back of the intake where you can use various fittings that allow one a source of vacuum.
I'm using a Edelbrock Performer Intake & a Holley carb.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 05-07-2007, 03:21 AM   #5
GREASEMONKEY72
GREASEMONKEY72's Avatar
the pcv hooks up to the port on the bottom of the front of the carb and the brakebooster line hooks up to the port on the bottom of the back of the carb(stock quadrajet and intake)
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 05-07-2007, 08:59 AM   #6
RustyParts
RustyParts's Avatar
I'm using an Edelbrock, took off air cleaner so you can see PCV.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 05-07-2007, 02:13 PM   #7
Moneypit
Ok but if I have the PCV valve in one valve cover, and the PCV Breather in the other valve cover, where do i put my oil in? I only have one hole in each valve cover. Would I have to take out the PCV valve and put oil in through there?
LOL! I just realized I put 'fell' instead of 'feel'. Now I really feel dumb!!
1968 Chevy C10
1967 Mustang
1976 Honda XL350
2012 Ram 1500 4x4
Old 05-07-2007, 02:20 PM   #8
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Pour your oil in the PCV breather hole
sneakysnake is offline   Reply With Quote
Old 05-07-2007, 02:45 PM   #9
bryanw1968
bryanw1968's Avatar
esll.
Clean motor. I like it!
bryanw1968 is offline   Reply With Quote
Old 05-07-2007, 03:03 PM   #10
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Now I gotta go check mine and make sure it's routed correctly..... Thanks for the pics guys!
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
