Old 05-07-2007, 01:38 AM   #1
ocbaud
Garage Queen Material
tranny cooler???
alright, in going about cleaning up some stuff on the truck, i'm trying to decide on something.
right now i have my tranny cooler hooked up inbetween the tranny and radiator cooler(the fluid goes through both)
i could make the engine compartment look MUCH cleaner if i just ran lines from the tranny to the aftermarket cooler.
i know a lot of people say its bad because you need it hooked up to the radiator also to help heat the fluid back up(or atleast thats what i've heard). But how bad is it really?
ocbaud is offline   Reply With Quote
Old 05-07-2007, 09:05 AM   #2
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Lightbulb Re: tranny cooler???
My trans cooler has allways been hooked up straight to the trans for many yr's. without any problems.
Everyone has there own theroy on whats correct and not, so i think it's just something you need to decide on how to set it up and just do it like that.
For the way most people on here use thier trucks it's not gonna be a problem.
But if you use the truck to pull heavy trailers and haul large heavy loads in the bed then you may want to hook it in series with the rad cooler.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 05-07-2007, 12:13 PM   #3
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
i have a tranny cooler that goes for the tranny to the aftermarket cooler that sit in front of the radiator. so if you look through my grill youll see a cooler then a radiator. cooler is on the passanger side and takes up ablut 1/3 the space the radator does. The truck runs cool and so does the tranny so im happy.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
