05-07-2007, 03:05 PM | #1 |
Front Rotor interchangeability?
Okay, my mind is still turning. I have a 73 + clip on the front of the truck (1" wide rotor) I want to get a 5 x 4 3/4s lug pattern. Does anyone know if there is a car rotor that interchanges with the 73 + rotor and is 5 x 4 3/4? I know, y'all are getting sick of me asking, but I am trying to find a feasable solution. If I change out the front rotors with new ones and get the rear axles redrilled, then i won't have to buy adapters (which I am hearing are bad)
Thanks!! Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
05-07-2007, 04:15 PM | #2 |
Living In The Past
Re: Front Rotor interchangeability?
I have some 1 1/4 inch truck rotors that have been redrilled to 5 on 4 3/4. they are practicly new. I bought from board member bigjimzilll I never used them and project went another direction if you are interested.
05-07-2007, 04:22 PM | #3 |
maybe a hollander interchangemanual could help you .
you allso can go to the local pick and pull and fisicly see wat will fit by switching parts around on the local wrecks
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
05-07-2007, 04:25 PM | #4 |
jorgensensc
what pattern is the rear axle?
05-07-2007, 04:31 PM | #5 |
Olden Days,
Will the 1 1/4" rotors work with my Calipers? I din't know you could swap rotors between the 1" andthe1 1/4". I may be interested if I can't find an easier local solution. Faribran, The rear axles are 6 lug. I figured I would just remove them and have them welded and redrilled for 5 x 4 3/4. Does this sound like a feasable option? Shawn
05-07-2007, 04:41 PM | #6 |
Living In The Past
I dont know what you might have to change to make them work. I was throwing that option out there for you if you know how to make it work.
05-07-2007, 04:43 PM | #7 |
i am always looking for new ideas...
i have a trans am rear i had considered putting under one of these trucks... was wondering how to make the front bolt pattern match.
05-07-2007, 05:50 PM | #8 |
i used a 70 impala front rotor on my 71 spindles to get 5/ 4 3/4, it has the same w/ bearings too.that way my 90 vette wheels fit.this is all on a 67swb
05-07-2007, 06:09 PM | #9 | |
Thanks for the info so far! Shawn
05-08-2007, 12:39 AM | #10 |
I cannot seem to find any '70 impala rotors, only 71 and up and they appear to be 5 x 5. Can you clarify this for me?
Does anyone know the stock diameter of a 1" wide 73-87 rotor? I can't seem to find it on the net. The 71+ impalas use 11" rotors that are 1" wide. I am trying to figure this out! Shawn
05-08-2007, 03:09 PM | #11 |
Olden Days i PMed you.
05-08-2007, 05:42 PM | #12 |
Living In The Past
here's some pics, Got them from board member bigjimzlll, I believe he had a local machinest where he lives redrill the rotors. the white stuff is just the packing peanuts, they are still in the box I got them in. I just opened it to look at them.
05-08-2007, 05:45 PM | #13 |
Look good. Will you Pm me a price?
Thanks! Shawn
05-08-2007, 05:48 PM | #14 |
Also, Can you measure the center cone part for diameter. I know I'm being a pain, but I have to make sure what I want to do will work, or it's all for not. Thanks!
Shawn
05-08-2007, 07:51 PM | #15 |
Living In The Past
not a problem.. looks like 3.055
