05-07-2007, 03:40 PM | #1 |
It Is What It Is,,,,
Bucket seats
1979 C-10 with org. bench seat, Im wanting to get a set of buckets in there and have a chance to score a set from a 73-87 GMC jimmy. Would those brackets bolt right on up or will there be some mod. to be done?
Thanks for any and all help.
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture My Rat Den |
05-07-2007, 03:50 PM | #2 |
Re: Bucket seats
The floor in the jimmys and blazer is flat where the pickups have a hump that the seat sits on. The jimmy seats would need to be modified to fit and may sit higher then the bench. Suburban seats would fit a little better but still need to be modified to bolt down in the back and the inside front mount on the seat has no hole to bolt to in the cab.
I can still count my vehicles on two... wait three hands. |
05-08-2007, 05:31 AM | #3 |
Re: Bucket seats
So is there any brackets or set of seats that just bolt up? or is any bracket going to require mods.?
05-08-2007, 09:47 AM | #4 |
Insert Witty Text Here
Re: Bucket seats
I hate to nitpick, but this is probably the most asked question on this board. Using the search would find you about 834,932 threads on the topic.
You can read up on your factory options here: http://www.73-87.com/7387garage/inte...ry_buckets.htm Otherwise, you'll have to fabricate something. The factory buckets are rare. I have never seen atruck with them. Slonaker |
05-08-2007, 11:19 AM | #5 |
Re: Bucket seats
I just restored a set of factory buckets and console from a 79, (I think). I'll have to cut the inner brackets off the floor of the 79 to make them work in my truck, an 85 half ton 4x4.
Pete |
05-08-2007, 12:29 PM | #6 |
glamoros piece o' lowlife
Re: Bucket seats
My '79 C10 got buckets in it, the front is supported by 2x4 blocks but it looks like the rear of the brackets bolts right up to the cab - pretty sure some of the previous owners swapped them in cause they ain't on the build sheet and it was a pretty bare-bones truck when it left the factory, but I ain't got no clue what vehicle they came off.
The more I drink, the more I drink, the more I drink... diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express |
05-08-2007, 05:23 PM | #7 | |
Re: Bucket seats
I looked for this topic for answers so I wouldnt be a "re-poster" But I guess I didnt look hard enough,,, no dis-respect Thanks for the help thow! Does anyone know who makes that kit?
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture My Rat Den Last edited by Mr79C10; 05-08-2007 at 05:37 PM. |
05-09-2007, 09:50 PM | #8 |
67 Chevy Stepside
Re: Bucket seats
you can go to my sig and click on my link and see my orig buckets
1967 Chevy stepside 1976 BIG DOOLEY 454 turbo 400 4:11 |
05-09-2007, 10:51 PM | #9 |
Flat Black, & Chrome!
Re: Bucket seats
I may be wrong here, but those appear to be suburban bucket seats to me. I was under the impression that the original buckets were low backs.
05-09-2007, 11:03 PM | #10 |
67 Chevy Stepside
Re: Bucket seats
up till 77 was the low back and half way in 77 they change to high back some early 77 had low back and late 77 had high back
05-09-2007, 11:20 PM | #11 |
That Guy
Re: Bucket seats
I had to cut the brackets(lowering them) and making my own welds and making a brascket for the floor. I usded seats from an 87 blazer.
model shot!!:
1978 Chevy Scottdale Stepside, 3rd engine- 350c.i. built with cam and lifters, holley 670cfm carb. and intake,heads shaved .60. Truck is a project, and I am its restorererer! |
05-09-2007, 11:21 PM | #12 |
That Guy
Re: Bucket seats
And notice they came out to high in the front so right now i turned the brackets around and theyre pretty even lol.
05-13-2007, 11:26 PM | #13 |
67 Chevy Stepside
Re: Bucket seats
find you a surb. and cut the orig. brackets off the floor
05-14-2007, 12:42 PM | #14 |
Re: Bucket seats
Are they the same brackets? I was under the impression that they were not because of the difference in the floors.
Slonaker EDIT: I just re-read the article I linked above on 73-87.com. It says the brackets are the same. Last edited by Slonaker; 05-14-2007 at 12:49 PM. |
08-17-2007, 01:26 PM | #15 |
Re: Bucket seats
I've got a set of factory buckets in my storage unit. They came out of a 77 or a 78 3/4 ton GMC. I've got the brackets to. I don't have a truck yet though. I really need to get a truck. Oh I have the console to.
08-17-2007, 05:17 PM | #16 |
www.73-87chevytrucks.com
Re: Bucket seats
Burb brackets are the same as a pickup basically. You need the hump "stand" in the floor from the burb and the rear mounts have to be bent to work, but they will work.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
08-17-2007, 05:50 PM | #17 |
Re: Bucket seats
i know that corbeau makes a bracket to mount their seats in our trucks that came with a factory bench seat. however, im not sure if they will work with non corbeau seats or not. im gonna hold off and get a set of their buckets and the bracket that goes with them. ill find the link
87 chev wrangler |
08-17-2007, 05:54 PM | #18 |
Re: Bucket seats
http://www.corbeau.com/prod_index/prod_index.shtml
thats the link to the seats http://www.corbeau.com/products/bracket/bracket.shtml link to brackets http://www.corbeau.com/bracket_guide/bracket.shtml thats the link to the bracket guide
87 chev wrangler |
08-17-2007, 07:41 PM | #19 |
STILL PLAYS WITH TRUX
Re: Bucket seats
Or you could what i did and just make some mount blocks out of aluminum like this.
This is the FWD INBD DR SIDE This is the FWD INBD PAX SIDE This is the INDB DR SIDE COVER Full view |
08-17-2007, 08:43 PM | #20 |
The Crazy Machanic
Re: Bucket seats
can i get a set of those mounts
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) * 1970 chevelle 2dr sedan Latest update June 24 2007. *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one |
08-18-2007, 08:11 AM | #21 |
Re: Bucket seats
[QUOTE=87 STEPPER;2314241]Or you could what i did and just make some mount blocks out of aluminum like this.
This is the FWD INBD DR SIDE Attachment 291390 QUOTE] Super nice Idea, Whats the size on that chunk of aluminum?
08-18-2007, 11:21 PM | #22 |
Re: Bucket seats
You may be better off just putting your seat & track in and taking some measurements im sure they will probably be different than what i have but it's just standard 6160 aluminum 1x2 stock cut to the hight required in my case it think it was either 2.5 or 3 " for both sides and then i just drill one hole down through it.
08-19-2007, 08:05 AM | #23 |
Re: Bucket seats
still a pretty kool idea. Its what I will end up doing or fab'n up something for buckets.
08-19-2007, 08:27 AM | #24 |
Dark Heart Motorsports
Re: Bucket seats
seeing all these bucket seats makes me so envious...no wonder Im always broke,,,,,tryin to catch up to yall! lol
How Deep Can YOU Bleed..? 1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter 2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD! |
