Old 05-07-2007, 10:38 PM   #1
harlyworkr
harlyworkr's Avatar
Disc Brake conversion
Can I put a set of 79 C10 disc brakes on my 69 C10? What is the difference?
Thanx in advance!
Mike
harlyworkr is offline   Reply With Quote
Old 05-07-2007, 10:52 PM   #2
st1x10
st1x10's Avatar
Re: Disc Brake conversion
You will have to change the spindles, ball joints, and tie rods to make it work. But in all reality the ball joints and tierods need to be changed.
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline   Reply With Quote
Old 05-07-2007, 11:00 PM   #3
krue
Designated A-hole!
krue's Avatar
Or you could swap the whole crossmember.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 05-07-2007, 11:02 PM   #4
harlyworkr
harlyworkr's Avatar
I have a complete front end from a 79 truck, if I swap the control arms, spindles, and tie-rod ends, will that work OK for me? Or, do I have to stay with a 71 or 72 disk brake set up? Doing a ground up restro but want to add disc brakes for modern braking.
Thanx again
Old 05-07-2007, 11:05 PM   #5
st1x10
st1x10's Avatar
Well just use the whole front crossmember if you have it.
2002 Chevy S10 V6
Old 05-07-2007, 11:08 PM   #6
krue
Designated A-hole!
krue's Avatar
Honestly I'd get the m/c and booster and front lines off of it too, if you have the whole thing. Check the FAQ (Index Link in my sig) for info on using the m/c and booster. The advantage to this is the ugly prop. valve is out of sight.
www.daveramsey.com
Old 05-08-2007, 12:04 AM   #7
GREASEMONKEY72
GREASEMONKEY72's Avatar
go for the whole conversion
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
