05-07-2007, 10:54 PM | #1 |
Hollister Road Co.
FYI on 55 - 59 Rear Disc's on a 10 bolt.
I ran accross a fellow truck builder (I for got his screen name here) last week end and saw his factory looking disc setup on the rear of his 59. He had a 77 nova 10 bolt axle with 1998 - 2001 camaro rear disc brakes and best of all its a bolt on deal. He had the calipers, brackets, e-brake setup, 12inch discs, bought off ebay for about $200, Sweet deal. The only draw back was you needed 16 inch wheels if thats really a draw back and you'll need `12 -12.5 dics on the front, again not a real draw back. So this should help those that are looking for rear disc on the cheap. I was impressed with how simple it was and how clean it looked. I believe that a nova and 3100 backing plate bolt patterns are the same. Nova is bolted and the 3100 is riveted.
05-08-2007, 10:29 AM | #2 |
polishing a turd
Re: FYI on 55 - 59 Rear Disc's on a 10 bolt.
that was me. i will take some pictures of the setup and post them.
it is the 98-02 f-body brakes (camaro, trans am, firebird) basically the years they had the ls1 in them. you just have to flip the bracket to get them to work (mount right on left, left on right)
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' Last edited by 1-ton of fun; 05-08-2007 at 11:24 AM. |
05-08-2007, 06:11 PM | #3 |
please do take some pics, ive been wondering how id upgrade to disk for the rear and this sounds like a good way to do that.
05-08-2007, 09:57 PM | #4 | |
Hollister Road Co.
It is a realy a nice simple disc setup Last edited by dwcsr; 05-08-2007 at 09:58 PM. |
05-09-2007, 12:14 PM | #5 |
I guess I need to start looking for some Camaro cores!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
05-09-2007, 04:08 PM | #6 |
polishing a turd
i think you can also use 93-97 which is a smaller rotor, and MAY clear 15's but i haven't researched that. the 98-02 is definitely the best upgrade around with 12" rotors with 1.75" single piston cast aluminum pbr calipers.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
05-14-2007, 10:40 PM | #7 |
polishing a turd
here are a couple pics on here:
http://f150online.com/galleries/albumview.cfm?num=4543
