Old 05-08-2007, 10:11 AM   #1
OLDCHEV4X4
OLDCHEV4X4's Avatar
oil coming out PVC?
My 86 GMC 3/4 ton 4x4 with a 350 is pushing out oil thru the PCV . I replaced the PCV valve and that didn't help. So i thought mabey the oil return holes in the head were mabey cloged up. so i pulled the valve cover,(it has center bolt type) and everything was fine. Anybody elese have this problem? The oil is getting all over the place.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 05-08-2007, 12:35 PM   #2
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
Re: oil coming out PVC?
How is yer compression (of the cylinders)? There;s only one thing that'd cause such an excessive oil suction at the PCV, and that's blow-by - under normal operation of a good-condition engine the oil itself doesn't get hot enough to build up the massive crankcase pressure that is needed for it to start spitting out... Go to parts store and rent a compression tester, then post yer findings.
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 05-08-2007, 12:40 PM   #3
OLDCHEV4X4
OLDCHEV4X4's Avatar
I got compression tester. How many psi should i have in a high milage motor?
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 05-08-2007, 02:25 PM   #4
Pyrotechnic
Pyrotechnic's Avatar
I've never compression tested a Chevy 350 but I did compression test the 4 banger in my friends Honda. They were all around 120-130 PSI with about 130K miles on the clock.
Pyrotechnic is offline   Reply With Quote
Old 05-08-2007, 06:19 PM   #5
Ivan D.
Ivan D.'s Avatar
Yah, I think 120-130 is about right.
Old 05-08-2007, 08:13 PM   #6
Ironhead
Ironhead's Avatar
Just did a compression test on 87 to find an ailing cylinder. I tested three cylinders until I came across the bad one. They were all +/- 140#.
Ironhead Mike
'68 Panel 402BB
'84 Shortbox 4X4
'85 Blazer
'97 Silverado Ext. Cab
Ironhead is offline   Reply With Quote
Old 05-08-2007, 11:52 PM   #7
cuda
You probably have blowby on all cylinders.
cuda is offline   Reply With Quote
Old 05-09-2007, 06:49 AM   #8
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
I have the same problem at running my trucks psi at a stop is about 30 psi and at go it 38psi if this helps any. I have the same isssue with the oil coming out at the top i was thinking if siliconing it, but im running an after market pvc cover thats crome from autozone so i think that might be my issue. Cause the fluid is not come the the grommit at the valve cover it coming from the one that seal around the top of the pvc to the chrom cap.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 05-09-2007, 10:22 AM   #9
Roper
I had a brand new 350 LM1 installed in a vehicle by GM a few tyears ago. That motor did the same thing after 5000miles. They had a harmonic balancer for a 400sb on it which probable screwed the motor.
Anyway they tore down the motor and couldnt find anything wrong with it. After months of me *****ing they finally replaced the motor with another new crate motor. This one had the right harmonic balancer! Anyway the new lm1 works great.
Roper is offline   Reply With Quote
Old 05-09-2007, 12:34 PM   #10
OLDCHEV4X4
OLDCHEV4X4's Avatar
Thanks for the reply's guys. I will do a compression check and let you know whats up.
But it dosent use any oil and it dosent smoke out the exaust, and broken or worn out rings would make oil smoke. Right?
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 05-09-2007, 08:53 PM   #11
piecesparts
Parts and more parts
piecesparts's Avatar
You could have a bad valve guide. You are definitely getting some blow by.OR
Just how do you have your PCV set up on the truck? Do you have a positive ventialtion setup on theengine or are you just running ventilated caps on the valve covers. The positive design would be that you have a PCV valve connected toyour intake m anifold and the other valve cover has either a ventilated cap or a hose attached to the air cleaner. (this is the cleanest way) If you are running just ventilated caps to the atmosphere, then the vapors will pump up in the block and push out onto your engine.
piecesparts is offline   Reply With Quote
Old 05-10-2007, 08:41 AM   #12
OLDCHEV4X4
OLDCHEV4X4's Avatar
I think i got it..... My 97 truck broke down yesterday and i had to tow with the 86. So i pulled the pipe off on the opposite side valve cover and there was a bunch of oily crap in there. I cleaned it out, hooked up the trailer and hoped for the best. I was stressed out obviously because i had one truck broke down and my best tow truck about to break down. And i had to tow over Welch mountain.
I made it back and there was alot less oil puking out than before.
So i think i'm gonna pull that other valve cover and check for crud.
Thanks for all the help guys!
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 05-10-2007, 02:23 PM   #13
edman87
junk collector
Been a whilesince I messed with a carbed motor, but in tbi vehicles it is very common for the port on the tbi unit to clog up and cause excessive crancase pressures. I had a 4.3 blow out valve cover gaskets and a oil pan gasket due to that pcv post plugging.
Check the whole system, anywhere it is baffled or has a hose or such can crud up.
'87/89/76 K5 in progress
'99 K2500 short crew
'91 camaro rs
'98 jeep tj
'52 willys cj3a
edman87 is offline   Reply With Quote
