Old 05-08-2007, 10:50 AM   #1
Critter
Future TOTM Winner
Critter's Avatar
Question Dana 44 rebuild
First of all, I know this would probably go best in the 4x4 section, but I generally get a better response here. I am in there process of rebuilding my factory Dana 44 front axel on my 72 K5. I have everything pulled apart except for the carrier assembly which I just assume leave alone if possible (everything seems clean and in good shape). I have some experience with rear axels, but this is my first time to be any deeper than the hubs of a 4x4 front. Anyway, there is a seal inside the housing (#31 on the diagram) that I am confused about. Is this seal just outside of the bearings, or is it farther out on the tube towards the hub? Do I need to remove the carrier assembly to change this out or is it done from the hub side?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 05-08-2007, 11:19 AM   #2
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: Dana 44 rebuild
You gotta pull the carrier.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 05-08-2007, 12:43 PM   #3
Critter
Future TOTM Winner
Critter's Avatar
Re: Dana 44 rebuild
That's what I was expecting. Next question. Are any special tools required or is it about the same as changing a seal on a wheel hub? Yank out the old one with pliers and evenly tap in the new one. I keep getting the idea from other places on the web that they are a pain in the @ss to swap out.
Old 05-08-2007, 02:07 PM   #4
Chris27
Blazerless
Chris27's Avatar
Re: Dana 44 rebuild
No special tools. The seals go in from the inside, that's why there a PITA (you have to dissasemble the entire axle). But if you have the diff already apart, it's easy.
72' K5 Blazer 4x4 350TBI/700R4/NP205 3/4 ton diffs. Daily driver. SOLD
69' Beaumont 388/700R4 11.70@116
77' Bronco, Wife's mall cruiser/poser 4x4. Capable but too pretty to go offroad.
Chris27 is offline   Reply With Quote
Old 05-08-2007, 04:08 PM   #5
Critter
Future TOTM Winner
Critter's Avatar
Re: Dana 44 rebuild
Thanks guys, that’s a big help. Being that I only want to do this one time (for a while, at least) can someone confirm a few things for me? I plan to change out:
#31 Oil seal
#49 Oil seal
#51 Oil seal
#52 Needle bearings
#55 Seal
#56 Inner bearing and race
#58 Outer bearing and race
Along with the upper and lower ball joint assemblies, steering joints, and cover gasket of course. Is there anything else I should change out? Everything inside the carrier seems to be in great shape. If I change out the differential bearings, I will have to have the carrier re-shimmed, right? Sorry for all the questions, I just want to make sure I am going about this correctly. Unfortunately I am on a very tight deadline to get everything put back together.
Old 05-08-2007, 04:54 PM   #6
Burt4x4
Burt4x4's Avatar
Re: Dana 44 rebuild
I would not touch the diff bearings. Your R&P adjustment shims are inbetween the bearing and the differential. Leave them be unless they fall apart when you remove it. They are pressed onto the diff. Make sure NOT to re-install the diff bearing retainers backwards, put them back in EXACTLY they way they were, # 19 in your pic.
A trick to removing that seal inside the diff housing is to use a broom handel from the wheel side and pound it out by simply using the broom handel like a slide hammer, works great and the wood does not mar or damage the diff.
D44 is perrty simple to rebuild once you get familiar with all the parts.
Good Luck
Burt
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 05-13-2007, 01:49 AM   #7
69TowRig
Re: Dana 44 rebuild
If you are taking it that far apart you should do the outer pinion shaft oil seal as well.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 05-13-2007, 03:55 PM   #8
EFI70Blazer
Active Member
EFI70Blazer's Avatar
Re: Dana 44 rebuild
Make sure you mark the caps for the carrier before you remove it if they are not already. They need to stay on the same side they came off of.
Here is a pic of a neat tool to install the inner seals.
I think i may make one when i do mine.
Also to get the carrier out without a spreader, put a wrench on one of the carrier bolts and against the case. Then turn the yolk to get it out.
Mike T.
Oregon
70 GMC Jimmy 4x4
70 Camaro LS1 plans in the works
71 RS/SS Camaro numbers matching
86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear)
EFI70Blazer is offline   Reply With Quote
Old 05-15-2007, 11:49 PM   #9
Critter
Future TOTM Winner
Critter's Avatar
Re: Dana 44 rebuild
Ok, Im tired of looking thru various online manuals and getting different numbers from each. What do I torque the bearing caps at? All I can find is info for the Ford D44s and Jeep D44s, and the numbers all vary between 60-90ft-lbs. Everything is going back together pretty good (the caps are just snugged down right now) Hopefully the axle will be ready to put back under the truck tomorrow!!! By the way, if anyone can find this torque spec in the good ol' Haynes or Chilton manuals PLEASE tell me what page it is on. I am about to lose my mind trying to find them!
